Question about Dryers
HELP, MY GENERAL ELECTRIC DRYER IS BLOWING COLD AIR
I BOUGHT A USED GENERAL ELECTRIC GAS DRYER
MODEL # DCLR333ETOWW
SERIAL # LS226872G
and it still runs pretty good except for the cold air. I really don't know if it
is cheaper to get a new one or fix the old one. I really don't have a lot
of money and I have 6 people in my family and we really need this
dryer to run...
Sincerely,
Mrs. Fix it
  • orlandoflabo Dec 17, 2008
    but my heating coils are perfectly fine
  • 240 Answers
More than likely, you have lost the element in your dryer. Sorry to say, but they are not that cheap (WE11X103, Price Retail $89.00), but if you think your handy enough, they do make a restring kit ( WE11X203, which sells for around $40.00). The issue, if you do it yourself, is that you have to re-wire both strings in the element. You would have to be sure that the coils dont touch each other or any part of the element housing, or it will short out. If you feel your up for it, here are the directions for getting into the unit. UNPLUG THE UNIT first off. Open the door, and look at the top of the door housing area for screws that may be securing the top of the unit. If there are screws, remove them, if no screws, put a putty knife between the top and cabinet, approx 1-2 inches from the side and pop the clips holding down the top. Lift and slighty pull top towards you and unhook the top. Spin the unit around, and remove the four screws securing the back access panel and remove the panel. Remove the belt from the idler pully, remembering the way it went for reinstallation. Go back to the front panel, and remove the two screws holding the front panel onto the cabinet. These should be just inside the cabinet around 2" down in the top front corner. Tilt the front panel towards you and lift off the bottom securing brackets. Make sure the loose belt is loose, then remove the drum by firmly pulling forward and lifting slightly. You may have to SLIGHTLY bend the cabinet to allow it to slide forward. You now have access to the element. Look at the two strings for breakage. You may have to gently push on them to find the break. Sometimes (especially with GE's) that one string has completly blew up, if this is the case, be sure to clean out all remaining peices of broke element. If you dont find a broken string, stop, and write me back, we'll check out the other issues it might be without tearing it down again, or wasting unneeded money. Get back to me (gjappliances@gmail.com) with anything else (problems, no string breakage, helping you find parts, etc) that you may need. Thanks and talk to you soon. JIM
Posted on Nov 06, 2007
I have a gas dryer model 97310100 blowing cold air will not dry, what could be the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | Kenmore 74622 Gas Dryer
All mechanical function work well except dryer will not heat up ,blowing cold air.Model DCLR333ETOWW GE
heatman101
Sep 01, 2011 | Kenmore 62822 Electric Dryer
The drum is turning but it's blowing cold air, no hot air not even warm. The last time it was used it was hotter than usual, but now nothing.
heatman101;
Aug 04, 2011 | Dryers
My condensing dryer tcm570p is running fine but will not heat up it is always blowing cold air?
heatman101
Jul 24, 2011 | Dryers
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
Dryer will not heat up- it is blowing cold air when it runs
heatman101
-\-0
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Blowing cold air only. no hot air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 21, 2010 | Kenmore 64672 Electric Dryer
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Dryers Logo
376 people viewed this question
Top Dryers Experts
