Question about Sony Ericsson W710i Cellular Phone
My cell does not get proper network, it does not receive signal in the area where it use to receive, that too is where other cell receive a strong signal with the same service provider
  • emm070 Jun 25, 2009
    but when i put other service provider it get network...at the same area where the original sim card doesn't, the original sim use to get signal before in that area.....
  • 4 Answers
This is network ic problem. change ic
Posted on Jun 25, 2009
How do i set up GPRS on a china I4 phone
Good day. Call your network provider, and talk to the online personnel for this matter. Ask assistant for configuration settings of your phone, they will automatically send you the configuration settings thru text message. Once you receive the settings save as default for your phone, then try to run the GPRS, sometimes it takes an hour to run for test, depending on your area if you have a strong signal. Thanks
Sep 11, 2011 | Cell Phones
Mine is W595 model , the problem is that my mobile gets cut whenever i talk , its like the mobile when i'm in call receives very less signal and eventually turns out to be no signal at al for some...
The strength of your signal depends on your where you are. This is because the service of your network provider is poor in your locality.
Try move to another locality where the signal of your network is strong and you will see the call will not cut.
Regards
Sep 02, 2011 | Sony Ericsson Walkman® W995 Cell Phone
It catches network when their is strong signal but in areas that are not having strong signals it says no network coverage
Keep in mind, poor reception is not something that your service provider will fix just because you want them to. It must be justifiably cost effective for them to put up new towers, which will ultimately be criticized by cities, home owners associations, etc. Most users think there is nothing they can do to improve their cell phone reception by themselves. This is most certainly untrue, and the following will explain what you can do to ensure great mobile coverage without waiting for a new tower to magically appear.
edit Steps
  1. 1Battery. Your cell phone uses a lot more power when connecting a call than when it is on standby. Often, your battery can be strong enough to attempt a call, but not strong enough to find a signal. If you find you are having signal problems, try to keep your battery charged to 2 bars or higher. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9503394424+9665908481+3607312525+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google
    enclosure antennas 900mhz,2.3ghz,2.7ghz,3.5ghz,5ghz dual polarized microwave antennas
    www.itelite.net
  2. 2Landscape. Buildings and other large structures are very unfriendly to cell phone signal. Rather than making calls from deep inside buildings try moving outside or to a window to place your call. If you are having reception problems on the street try walking to the nearest intersection as they typically have better coverage. Cellular band radio waves do not effectively penetrate earth: if you are underground you will likely receive no signal.
  3. 3Install a cellular repeater. If you are having cell problems in one location, such as your home or office, then try installing a cellular repeater. Cell phone repeaters pick up low cell signal with an antenna, boost the signal and broadcast it over the coverage area. They typically need at least 2 bars of signal where the antenna is placed (usually outside or on the roof) but can substantially improve cell reception, as well as battery life and data download speeds. Some repeaters might need technical knowledge such as the frequency of your carrier, and only work for one service provider. For a less technical approach that improves reception on all carriers, use a dual-band cell phone repeater.
  4. 4Upgrade your antenna. A few cell phone manufacturers make a "Hi-gain" antenna for their handsets, which may be changed in-store or by the user at home. Although these won’t improve signal as much (or at all) as a repeater these antennas are relatively inexpensive and you are not confined to one location.
  5. 5Change networks. Most networks operate independently of one another, using their own frequencies and constructing their own cell phone towers. Chances are if the signal is bad with one network you can improve by switching. Most cellular networks these days allow you to transfer your phone number when you change provider.
  6. 6Hold your phone correctly. Mobile phone antennas are designed to project a signal outward, perpendicular to the long axis of the antenna. As such, mobile phones seek signals in a donut-esque shape around the antenna. Normally, when a mobile is held upright, this is not a problem. However, if you are holding your phone in a strange way, such as on its side or upside down, you will hinder the operation of the antenna. Hold your phone upright to guarantee that your phone can "see" your carrier signal.
  7. 7Host a cell site. This may take time, but where cell phone reception is inadequate property owners can host small cell sites on their properties for major wireless carriers. 3rd parties with Wireless Revenue Programs allow you to register your property to be eligible. Then when there is carrier interest in the area you'll be on the short list of places they choose from and will have optimal coverage. They may even pay your phone bill.
Aug 29, 2010 | Cell Phones
Cellphone no signal
In your phone there will be a inductor antenna which receives signal. The inductor might not function properly. Contact service persons for that. But before tat in settings - Network selection select manual and check if it shows any networks. If it shows then the area has limited or no coverage.
Regards, Kesav
Mar 02, 2010 | Nokia 6300 Cellular Phone
Reception/signal not found in a strong reception area
take the phone to a mobile center and ahve them check the antenna on the phone
May 31, 2008 | Nokia 6120
Nokia mobile phone
Check network settings on your phone if those are correct. If those are ok then you may have a problem in your phone hardware.
May 22, 2008 | Cell Phones
HP compaq nc 6000
jdawg01,
the signal that receives by ur adapter is not that much strong so it was unable to connect properly..u might have receive a low signal..
Apr 06, 2008 | Computers & Internet
FREE CALLS AND SERIVICES IF I WANT PLZ
Roaming IS free. Roaming means your mobile changes from network to network depending on how strong the signal is. It can cost you more to make/receive calls, when using a network that you don't subscribe to.
Internet/Wap/GPRS are free in some countries, where I live, I can stay online 24/7 it wont cost me anything more than batteries. You'll have to check out what's availlable in your area. Ask your service provider and check out adds.
Mar 22, 2008 | Cell Phones
Every time I try to make or receive a call my phone hangs up.
-Select network manual in handset
-Try in other area
-Try other sim card
-Charge the battery atleast 6 hour
Nov 11, 2007 | Motorola Mobility RAZR V3
Sony Ericsson W710i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
