Question about Acer TravelMate 342T Notebook
Booting of CD Rom
My Acer Travelmate 342T Isn't Booting of the CD rom. Pleace help me !!!
  • 1 more comment
  • Ading Hermawanto Jun 25, 2009
    Yes I have had, and that isnot good, and my acer is not booting
    that is I had
    ( semula saya lakukan booting dan ok bisa tapi ditengah-tengah eror heng lah... na sape sekarang tetep gak bisa dibooting padahal kasusnya...disk read eror, terus dierintah untnuk direstart, setelah dilakukan tete kondisinya eror, dan diperintah untuk direstart.
    that is I had, the cd is good and my acer not read or booting prom that cd
  • 615 Answers
If Your Travelmate comes with Preloaded operating system.You must have operating system Cd. If it is not u r not having operating system CD. may u r trying using driver and documentation cd.It is not a bootable operating CD.
2.if u r using right cd then go to bios setting select option cd as first bootable device.
if it solves u r problem
rate me
Posted on Jun 25, 2009
  • Chandrashekhar N.G
    Chandrashekhar N.G Jun 25, 2009
    1.First check Your CD Rom is Working or faulty
    2. Check the cd in other PC
    3. IF yes Copy disc to Disc in another pc then try with duplicate disk.
    President:
  • 627 Answers
Change from bios the boot order
    Genius:
  • 2,785 Answers
Plz check the cd is working in another pc
I have Acer TM 4150. I has booting problem like when i put on my laptop it gives message to boot from 1- floppy drive 2-HDD 3- Cd Rom also in Cmos it shows no Hard disk or O HDD i restart it again...
Isssue with your Hard Disk... Possibility Data lost, due to power lost, or Bios Battery need to be change... To do So, Press and hold del button while you turn on your Laptop this wil bring you inside you Bios then Check carefuly set date and Time also set autodetect hard drive and set cd-rom first hard disk 0. second then the rest off... press F10 to save your change then restart your laptop then see if it will boot from itself.. if not ...Then put your XP CD on the cd-rom then re-start then press F-12 then chose Cd start to re-install your windows make sure you have your Cd key first then from anoter computer go on the net and download all your drivers for your laptot type down the model off your Laptop then on any browers type exemple; download ACER TM4150 drivers for xp or the one you use.. sample is that.. Good Luck
Oct 01, 2010 | Acer TravelMate 2303LCi Notebook
How to go the bios setup travelmate 342t acer
F2 - BIOS Menu and change Boot order to CD - 1st Boot Device
Jan 16, 2010 | Acer TravelMate 342T Notebook
How to reformat acer travelmate 345T laptop using external cd rom to boot the xp installer?
What is it you are trying to do?
If you are trying to reinstall the operating system, you can do that by booting from the Windows install CD. It will give you the option of reformatting and reinstalling.
Dec 01, 2009 | Acer TravelMate 345T Notebook
Acer travelmate CD drive changing
Dear,
u have to remove the screw behind the laptop and oppsite to CD rom.
Cheers
Sep 19, 2009 | Acer TravelMate 4150LCi Notebook
How to replace Acer travelmate 4011 CDROM
Look underneath at the base plate
Under the CD-Rom unit there are two screws with arrows against them
Remove these screws
Get a paper clip and press it into the small hole on the front of the CD-Rom and the loading drawer will spring open
Use this as a lever to gently pull the unit forward and out
You may need to rock it slightly from side to side
To fit new one . just slide it into hole and press
Jun 19, 2009 | Acer Computers & Internet
Dvd disc is not working
You likely do not have a DVD-Rom. Check the front of the DVD and be sure that it says DVD-ROM on it. If it does not you may consider contacting Acer to upgrade it.
May 19, 2009 | Acer TravelMate 2480 Notebook
My driver cd is broken
Just go into Device Manager and uninstall the CD-ROM that is listed. Next Click on Scan for Hardware Changes. This will automatically reinstall you CD-ROM Drivers. They are included with all the Windows Operating systems. Next reboot your computer and I think this will solve your problem. If this doesn't resolve the problem you probably have a defective CD-ROM.
Apr 07, 2009 | Acer TravelMate 4150LCi Notebook
How to replace mo on acer 342T.. cannot open motherboard out of
If you go to this site you can get step by step instructions on how to take it apart.Hope it helps.
http://htcwizardweb.net/node/2584
Jan 17, 2009 | Acer TravelMate 342T Notebook
CD ROM Boot
In the BIOS are you able to "discover" the CD-ROM device? There should be a way such that you can specify what devices are connected to the system.
The BIOS version should recognize what devices are attached to the system.
You may need to "flash" (upgrade) the BIOS. Now a days, BIOS upgrades are available on the manufacturer's website.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Acer TravelMate 2702WLMi Notebook
Acer TravelMate 342T Notebook Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
