Question about Car Audio & Video
Hi I'm looking to find out about how much fibor fill in a sealed box for a Boss blade extrem DVC 1200 peak running at 2 ohms, and The amp is a boss D3600 The box Dem are 18w 15h 11d. It comes out to be 1.225cf and the speaker box would be .8cf
  • 578 Answers
You to built the box according to the spkr spec's
Posted on Jun 26, 2009
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
I have 2 boss 2400 watt 15 how much watts do it push out for real 2000 or 1500
These units have a peak power rating of 2400 watts however they only have an rms or nominal rating of 1200 watts each. if this helped please help me by marking this as the answer, cheers
Feb 04, 2015 | Boss Car Audio & Video
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
Sep 21, 2014 | Briggs & Stratton Briggs Stratton...
What would be the best way to wire 2 1800w 4 ohm boss compact speakers to the boss cx950 amp
As the amp cannot support a 2ohm load you have to hook each sub up to one channel on the sub and you can't run them in bridged mode.
Mar 09, 2012 | BOSS AUDIO SYSTEMS CX950 Car Amp
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
How do i wire 2 fosgate punch 10" subs to this boss iq 680.2 amp? the subs are rfd2210 hx4 and theres two subs in a separated seald box. i need to know how to phase all the vcs together
Your subs are 4 ohm dvc so lower the impedance more power from your amp. I will include a link that will show you how to wire your subs for maximum performance. I would explain it but seeing the drawing will make more sense....
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 23, 2010 | Boss IQ 680.2 Car Audio Amplifier
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
How much air space
Air space needed around the sub is a minimum of 1 inch, but 3-7 is preferred. If you get too big you can get an echo sound. Sealed is my preferred box - it generally gives you the deep base thumping you are probably looking for.
Hope this helps! Rate my solution!
Jan 05, 2010 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
