Question about Scanport N9 19" LCD Monitor
Where can I get a new backlight for my N9 lcd monitor?
  • 3 Answers
Go to www.ccflsurplus.com and select the right product.
Posted on Jul 07, 2009
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
Monitor flashes black and white rapidly like a strobe light.
The easiest way to check this problem out is take your monitor over to someone who has a computer or if you have an extra computer at home hook the monitor up to see if it stops doing this. Then you will know if it is not the monitor. Then you can focus on the video card going bad or is bad. Change the card with a new one, problem is solved. Check the cables connections make sure they are not loose as well. Restart you computer also discharge it by pushing in the power button in while the computer is unplugged from the wall. John
Jan 13, 2011 | Scanport N9 19" LCD Monitor
Scanport N9 Monitor Model #M19FBK flashes one time and goes dark.
Not likely it got damaged in the move.
Make sure the plugs are firmly seated. That is, the power cord and the video plug at both ends.
Apr 18, 2010 | Scanport N9 19" LCD Monitor
I no longer have power to my monitor; is there a way to check power source or, if necessary, to buy a new power source pack?
You can measure the adapter output with a voltmeter. The output should match the voltage marked on the adapter. This model uses a 12-volt adapter.
If the adapter doesn't have any output, it may be because the wire has broken inside the cable near the plug from flexing. It's possible to repair this by soldering on a new plug. Sometimes it's tough finding the right plug, though; some brands of equipment use oddball sizes.
You can also purchase replacement adapters. Several sources came up after a search for "scanport n9 adapter". Here's one on eBay. You'll be able to find what you need.
Mar 05, 2010 | Scanport N9 19" LCD Monitor
Does the lcd monitor have buld in speakers? i have no sound on my computer
Yes it has, did you put the cable in the screen?
No, check it
Yes, if you have a cd (by the screen when you bought it) then install it on your pc
Oct 15, 2009 | Scanport N9 19" LCD Monitor
My monitor shows a blank screen .But when I press the RGB, DVI button, I can see my desktop for a second then it stops displaying. I have to keep pressing the button to change the display type in order to...
moneyshaker, Maybe your screen (LCD panel) is not blank, just BLACK!!! First thing to do is the flashlight test! With monitor connected to a KNOWN GOOD fully booted pc with WIN-desktop showing, reconnect N9 lcd to pc. Then and only then turn on N9 lcd. Note what you see or don't see!! If screen flashes on for 1 sec and goes to BLACK, then shine a bright flashlight 1" form screen at different angles and note if you see or don't see the desktop. This is only a test to check the condition of the unit's power supply and or INVERTER circuit. If you can still see the desktop even though the screen appears BLACK, then the "switch-mode-power-supply" is only partly bad. You did not state age of your unit? Most likely your problem is that the SMPS is detecting a fault in the INVERTER circuit that provides 800 to 1200 volts to light up the "cold-cathode-fluorescent-tubes" that are hung on the rear of the Clear Glass LCD panel and in front of a mirrored reflective surface. GEE wiz If I could take these long, straight, CCFT's and turn them into coils and mate them with an electronic ballast circuit called a CONVERTER circuit (ac to ac) and put them into an oversize light bulb screw-in base I could make millions.... Oh ****, That's already been done!!!! Oh! so that's how those new CFL lamps work. I suspect that your INVERTER (dc to ac) has almost bit the dirt. It will need to be looked at by a tech type person or you could visit Youtube and chcek for video clips that deal with monitor disassembly and or repair of the 2 most common LCD monitor failures. Look under "swollen electrolytic filter capacitors" and BAD capacitors, and Poor soldering and /or poor factory oven REFLOW SOLDERING and or Thermally intermittant soldering connections on printed circuit boards. This is only a guess as to what plagues you monitor. Please rate this response on fixya if it was of any help at all. im'louie12fix on fixya or lmistyrel @aol .com
Oct 06, 2009 | Scanport N9 19" LCD Monitor
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
THANK YOU FOR YOUR FEED BACK
Possibly you can if you go to their website . FIXYA is not the manufacturer 's support
Mar 31, 2017 | Scanport N9 19" LCD Monitor
N9 LCD MONITOR
Hi
Check if there is power coming from the wall socket.
If the wall socket is functional, then try with another power cable.
If this also doesnt work, then the monitor has to be serviced.
Feb 25, 2008 | Scanport N9 19" LCD Monitor
H21 LCD Monitor -No display
With that many boards, it probably has a separate ballast (inverter) to run the lamps. In the power supply section, I would look for bulging electrolytics and bad connections. In the ballast I would suspect a shorted output transistor, a bad output transformer, a bulging capacitor or bad connections.
Jan 19, 2007 | Scanport N9 19" LCD Monitor
Scanport N9 19" LCD Monitor Logo
48 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
richie46
ray gallant
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
