Question about Nokia 7500 Cellular Phone
My nokia 7500 ran out of charge and switched off. I have been trying to recharge it and switch it on but it is not switching on. When the charger is inserted it shows the charging sign, but I'm not able to switch on the phone. After a minute or so, the light on the screen goes off but it shows its charging in the background. Although I have kept it charging for quite a while, it doesn't seem to have charged and it isn't switching on. What do I do?
    Scholar:
  • 136 Answers
Check if the battery is alrite, you can get it checked by a technician for free using a multimeter, If its dead you need to replace it.
Posted on Jun 25, 2009
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
NOT SWITCHING ON
1. Try using batteries that are charged in a "different" charger.  Rechargeable batteries designed for cameras are interchangeable as long as they are the same "type" (ie. AA, AAA,etc)
2. I suspect it is the "charger" that is not working correctly.  Take it back if its covered under warentee.
3. If it isn't under warentee buy a new charger or buy re-chargeable batteries with a "high" power rating 1800 Ah plus that come with a charger.
4. If all this fails then you need to go back for replacement or repair depending on your warentee situation.  But try the number one first.
Oct 30, 2007 | Fuji FinePix M603 Digital Camera
Nokia e71 is not charging even if it plug in. it does not start with power switch and before it was switching off automatically
The charging point have faulty but depending when you will get it fixed you can always use a universal charger(desktop charger)
Feb 11, 2011 | Nokia E71 Smartphone
Alarm goes off when recharging the battery.
try turning on ignition switch before hooking up charger, once charger is working turn switch off.
May 10, 2010 | 1992 Pontiac Bonneville
My nokia 5310 is freezing at starting up from off position to on and then would not be switched off again,until disconnecting its battery. and when trying to charge the battery there is no symbols...
guys if your xpress music phine doesnt start completely..this is what you must do...
remove sim card/mem card
put the charger atleast 1 minute to recharge the battery ...
after 1 min. remove the charger and open your nokia phone it will start completely ..its proven just try it..
Apr 14, 2010 | Nokia 5310 Cellular Phone
Nokia 3110 is switching off automatically,battery not charging
Sounds like the battery compartment leads are corroded.
When you open your phone and remove the battery, you should see three pins sticking out. Clean these pins with some q-tips and a tiny bit of vinegar. Also try scratching the surface of these pins with a knife or screwdriver.
Also consider that the charger might be faulty. try checking with another charger (there should be someone you know with a 3310-charger lying around)
Dec 13, 2009 | Nokia 3110 Cellular Phone
Switch on!!!!
PLUG IN CHARGER AND SEE IF IT STARTS TO CHARGE IF IT DUSE NOT GET NEW CHARGER IF IT DUSE START TO CHARGE TRY TO TURN ON AS IT IS CHAGRIN IT SHOULD COM ON MAKE SHORE THAT THE BATTERY IS HOLDING A CHARGE
Jan 10, 2009 | Nokia 3110 Cellular Phone
My Nokia 2310 suddenly switched off. It didnt switch on again. I tried putting the battery(of problem phone) into another cellphone, the battery works fine. I tried to charge the problem phone, but is not...
I tried to charge the problem phone, but is not showing any activity upon inserting the charger jack. Other phones are getting charged using the same charger.
Any idea of what the problem could be?
Jul 29, 2008 | Nokia 2310 Cellular Phone
Fuji S9600
If you are using rechargeable batteries check the output of your charger, a 900mah charger will not charge 2800mah batteries to their capacity.
Stretch.
Mar 25, 2008 | Fuji Finepix S9600 Digital Camera
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Nokia 7500 Cellular Phone Logo
126 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
