Question about Philips Magnavox MS3652S 36" TV
Need to know what's wrong with my tv
Our projector tv has green warping lines in the middle ,some times it looks good all but the words might look a little distorted.I need to know if there's anything we can do.It is a magnavox.
  • 934 Answers
Nailtek,
You may have filed this one in the wrong place. A maggie MS3652S is a 36" crt based model, with a L01.1UAC chassis. But you start off your explanation as if it were a projector TV. Check the model and series again and let me know if I can help...
William Rayburn, CET
Premium Technologies
premtech@willapabay.org
Posted on Nov 05, 2007
It has a wavy line through middle of screen with like white light shining through it in three places. I do not think it is the convergence, when I go to convergence screen the red and blue will move but...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Apr 30, 2011 | Mitsubishi VS-55609 55" Rear Projection...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
I own a panasonic pt-ae900e i have notice a thin uneven green transpairant line in the middle of the screen lamp time 1987 hrs
Experience:
There is three LCD (liquid crystal display) in your projector when one LCD faulty he display a line some time flickering line one or two lines. Due to other two LCD is working well so this line is looking transparent. If BLUE LCD faulty than the line color is very light green or yellow.
Second option is this that your projector lamp life is near to end and after 2000 hours projector is very dirty inside and need service.
(service of LCDs and other parts of projector is a very technical job and I don't know you can do it or not)
Jan 16, 2011 | Panasonic PT-AE900U Multimedia Projector
My tv has a green shadow on lines or words on top that dips down in the middle of the screen
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 01, 2011 | Hitachi 57S715 57" Rear Projection HDTV
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 05, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Picture is bending at the top and bottom and looks 3d
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
MITS WS-65869 The green CRT is creating a warped image.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Warping
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Philips Magnavox MS3652S 36" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
