Question about Toshiba 57H82 57" Rear Projection Television
Power indicator light blinks on a 55 rear projection
SOURCE:
BMW Rider
  • 232 Answers
SOURCE: Toshiba 55" rear projection
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
Posted on Dec 10, 2007
shaggyrat
  • 1224 Answers
SOURCE: Toshiba problem
did you try power reset leaving unpluged for 5 minutes
it might be the power house component went out
do u get sound at all
this might be indicator of bulb replacement if no picture but sound
Posted on May 09, 2008
  • 185 Answers
SOURCE: 1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Posted on Dec 26, 2008
jerryg50
  • 1691 Answers
SOURCE: My Toshiba Rear projection TV Has A blinking power light
The power supply is in protect mode. There is most likely a short on one of the boards, or the high voltage generator, or a scan amplifier, or the power supply itself has a failure. Without troubleshooting the set it is impossible to know.
Jerry G.
Posted on Feb 23, 2009
  • 13 Answers
SOURCE: Power indicator blinks; but no picture.
Likely to be the STK convergence chips causing a protection circuit to cut in and switch the TV off when turned on. Do you hear clicking when you switch on?
Kelvin
Posted on May 28, 2009
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
When you push power button green light comes on and starts to power upfor just a few seconds then it will shut off
You can access the self diagnosis feature by pressing the menu and the Input/device buttons both in for 6 seconds then count the two digit blink code from the power indicator. The two digit blink code will repeat several times. Let me know the code.
Jul 21, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55819 turns off after about one second upon power up. Help
try the self test: when it goes off press and hold the menu and input buttons at same time for about seven seconds and release both.
power light blinks two digit code like, one blink, two blink, a pause and repeats it several times, this code will indicate area of problem.
sj
May 17, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 55" philips hdtv;it won't come on either by remote or button on tv
Does the power indicator blink? If so how many blinks is it blinking before it goes out?
May 04, 2008 | Philips 55PW9363 55" Rear Projection...
Blinking power light
General IIC error. An experienced technician will have to repairthat problem, as you need specialized equipment.
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
Dont have a remote
A green blinking light usually indicates an internal problem. The service person can use the pattern of the blinks to determine the problem.
Jan 08, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba 57H82 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
