Question about Canon PIXMA MP160 All-In-One InkJet Printer
My canon i560 had error 6000. What is? - Canon PIXMA MP160 All-In-One InkJet Printer
    Problem Solver:
  • 24 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq20
Posted on Sep 05, 2009
  • 615 Answers
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Jun 25, 2009
3 Suggested Answers
komguy
  • 2306 Answers
SOURCE: my Canon i560 stopped printing- snall window
That error says the purge assembly is not moving properly, check for paper stuck over on the right where the printhead parks, also if the squeegee is stuck over the cleaning pads you need to push it back to allow the pads to come up properly.
Posted on Jan 10, 2010
pineworks
  • 4041 Answers
SOURCE: SERVICE ERROR 5100 CANON I560 PRINTER HOW DO i FIX THIS?
Hi There
You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
Paper thickness error Canon I560
Align paper to left or right. Try to print on other positions or Change paper.
Jun 08, 2010 | Computers & Internet
Getting an error 5100 on my i560 printer
error 5100 & flash 2 times, you need o replace code strip or carriage unit or logic board
May 27, 2010 | Canon BubbleJet i560 InkJet Printer
The orange error light is flashing 5 times in between the green light.
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Jan 27, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i560 stopped printing- snall window
Jan 10, 2010 | Canon BubbleJet i560 InkJet Printer
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
I560 error code 5200
Orange 10 5200 Replace the BJ Cartridge(Printhead)
Cartridge Overheat 8 x
7 times in orange/green 5200 Cause: The print head's temperature is abnormally high tnx and good day!!!!!
Apr 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet... Problem:
Go to the Canon website address.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=9282#SupportDetailAct
Then type the word BLINKS where it says, "Please enter your question"
This will give you a list of the error codes for blinking leds.
Mar 19, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
733 people viewed this question
old marine
old marine
