Question about HP PSC 1410v All-in-One Printer
It does'nt print all the picture
Sometimes when i give command to print a picture, using Microsoft word 2003, it prints 1/3 and shows the message on my screen- ' the document failed to print.
What can i do, in can't solve it using the troubleshooter.
    Sergeant:
  • 145 Answers
Check the driver, is it installed properly...or the cable..try reinstall the driver, or maybe you set a wrong default printer
its just software problem
Posted on Jun 25, 2009
The ntvdm cpu has endountered an illegal instruction. Cs:0df1 IPL01f6 OP: ff ff 00 00 ff
SYMPTOMS
When you attempt to run a 16-bit program on a computer running Microsoft Windows NT 4.0 Service Pack 3, the program may quit immediately, or you may receive the following error message:
Hidden Console of WOW VDM
The NTVDM CPU has encountered an illegal instruction.
CS: 04c3 IP:3937 OP:c71c 9d 37 00
Choose Close to terminate the application.
When you click Close, you may receive several similar error messages.
CAUSE
This behavior can occur if you use an incorrect version of the Command.com file. For example, this issue is known to occur if you use a Command.com file included in Microsoft Windows 95, dated 7/11/95.
RESOLUTION
To resolve this issue, replace the Command.com file in the Winnt\System32 folder with the same file from another computer that is running Windows NT Workstation 4.0 or Windows NT Server 4.0, and then make sure that there are no Command.com files dated 7/11/95 on the computer. You can also replace the Command.com file on the computer with the same file on the Windows NT installation CD-ROM.
PROPERTIES
Article ID: 245184 - Last Review: November 1, 2006 - Revision: 1.1
APPLIES TO
Microsoft Windows NT Server 4.0 Standard Edition
Microsoft Windows NT Workstation 4.0 Developer Edition
Jul 22, 2014 | Dell Computers & Internet
Tip
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
on Mar 26, 2010 | Microsoft Word 2003 for PC
Printing is not happening with Outlook 2003
when you give print command from outlook mail just see which printer you selecting if have more then one printer remove it and set the default printer .when you giving print command choose the paper type also correctly.
Sep 15, 2009 | Microsoft Office Outlook 2003 for PC
List the steps to get a printed screen of an error message
Press command-shift-3 to take a picture of the screen. This will create a file named "Picture 1" on your Desktop. Double-click that to open it in Preview, then use command-P to print it.
Aug 13, 2009 | Computers & Internet
Printing emails no longer possible
I found a solution here.
It says that you have a registration problem with ole32.dll
You can fix it by running the following at a command prompt.
regsvr32 ole32.dll
I hope it helps.
Apr 13, 2009 | Microsoft Outlook 2003 for PC
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Print area in worksheet
1. Select area you want to print.
2. When you click Print, you getting Print window.
In "Print what" frame choose "Selection" option.
Sep 17, 2008 | Microsoft Office Professional 2007 Full...
Outlook 2003
There are many problems when using different versions of Outlook and Word, especially when word is used as the software for editing emails under tools --> Options --> Mail Format
Try disabling using word as the editor to prevent problems such as this.
Mar 25, 2008 | Microsoft Outlook 2003 for PC
HP PSC 1410v All-in-One Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
