Question about Intel D101GGC Motherboard
D101GGC JUST STOPPED
I was moving the computer and disconnected it to move it powered it down, when i hooked it back up and when to power it up nothing happened just a rapid green light on the board please help
  • mannnrulz Nov 22, 2007
    My system was working well and good the last time i worked on it and the very next day when i switched it on it doesnt gets boot,,,,just a green light keeps on flashing but system is not etting on..there is no display on the monitor so i tried my ram also with one another system and it was working good with that..hope u can help me out...
I have the same problem
tried the ram and the cmos thing but still gettin only a flashing monitor light
Posted on Jan 11, 2008
  • 385 Answers
Hello Spawn11455,
Maybe you can try taking out the ram and reseating it back properly. If that doesn't work, then maybe you can reset the cmos settings. That is a little jumper near the cmos battery that you have to remove and place on pin 2 & 3 and then put back on pins 1 & 2.
Good luck,
Lolita
Posted on Nov 05, 2007
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Computer will not turn on
It sounds like your power switch (the buttone you push to turn on the computer) is stuck, or you have a bad power supply (that provide power to the computer). Electric components sometimes go back if they are not used often.
Aug 18, 2009 | Computers & Internet
Keyboard not working-no power
Double check in the ends of the plug to make sure you did not bend or break any pins when you plugged them back in.
If you did then it is quite possible you need new and that you should also check the sockets on the back of the computer to make sure they are not damaged either.
Aug 17, 2009 | HP Computers & Internet
Lexmark X2350 All in one software will not install. Also, nothing happens when scan button is pushed. Also, no imaging studio installed.
Lack of info. Does the head move or jog when the machine is turned on.
If so can you remove the glass plate and with the power unpluged to the all in one can you move the head down the track? Plug it in and turn the unit on to see if it retracks
If so disconnect the power again and then reassemble the all in one! Now as you turn it back on press the scan buttons many times and the number pad to see if it will confuse it's boot sequence.
turn
Jul 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Sony RX540 had a program that would not shut down after repeated attemps to turn off the computer to reboot. I cut the power strip to have the system shut down after unpluging the computer and plugging...
Replace the power switch as it is either broken or stuck 'on'. You can purchase them pretty cheap (around $5) and are easily replaced providing you have motherboard/computer case documentation. Even if you don't have documentation, the motherboard usually has it written (typically in the bottom left or right of the motherboard) very small where it should be connected to.
Power Switch
Jun 09, 2009 | Computers & Internet
Broken Computer
jkdhksjdfh
sdlfds
fdslkf;gjufe
kg;drpgk
efpkgek
hk
p
Mar 13, 2008 | Computers & Internet
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
My computer wont power up!!!!!!!
Some PCs has an ON OFF switch on the back, did you check it?
It also could be possible that after you moved it some cable inside is loose.
Open it, check all the cables, connect power and see if on the motherboard you have any LED on. If not test the power supply or change it.
Oct 16, 2007 | Compaq Armada E500 Notebook
Freezing
I felt like an idiot when I couldn't fix this problem. Take out the battery and put it back in.
Apr 15, 2007 | SanDisk Sansa m230 MP3 Player
Intel D101GGC Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
