Question about Kenwood Food Mixers
Noisy bearings i presume it's the bearings that are making a terrible noise. The mixer has not been used for years. How do I get inside to grease it? TIA
  • Diane Lamb Jul 23, 2009
    Hi BGR1. It is a 'Kenwood Chef Excel' model # KM210 and we think it's about 20 years old.
    Even though I think the bearings need greasing, since standing and not being used for years, a small amount of oil has leaked from where the attachments click into place into the bowl.
    While using the mixer now, I've had a splash of oil dripping into my biscuit mix each time.
    I hope that all makes sense and that you can help me. TIA tim2george
  • Diane Lamb Jul 28, 2009
    Hi BGR1, thanks for your help. If you could send me pics that would be great.
    My email is dianenick_75 at hotmail dot com.
    Warmest regards
    tim2george
Hamilton Beach Stand Mixer leaking grease
That would normally signify that that particular part is getting hot. Try and get inside that head and clean the old grease off and replace with High Melting Point Grease. This is the sort used on car wheel bearings.
Feb 05, 2016 | Hamilton Beach 800 Watts CPM700 Commercial...
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
Oct 17, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My mixer makes a grinding noise when I use it...where do I put oil in the mixer to stop the grinding sound?
The only place that could ever needs oil is the back motor bearing, and unless you are very mechanically inclined it is a major job. You need to remove all of the electrical components and the motor armature to get to this bearing.
It sounds like you may have a bad bearing. It is possible it just needs grease, but here again, this is a job for a mechanically inclined person. This involves removing the mixer head from the base and removing the lower section of the motor housing. If you do decide to do this make sure you have a new gasket and FOOD GRADE grease. These can be purchased on ebay.
I have rebuilt 10 of this style mixer. If you decide to attempt this yourself, let me know and I will give you my contact info. I will try to walk you through it. and I have one similar to yours that I have taken apart so I could send you pictures.
May 29, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer makes a clattering sound at low speeds - seems to be coming from the governor or the control plate - any ideas, is this a common problem and how should I approach it?
Did it start clattering before or after it was re-greased? The K5ss by Hobart is an excellent mixer and there is no reason why it can't go on for a bunch more years. First you can get clattering if the brushes are less than 5/16th inch long, But that is not usual.
I would think that the rear bearing which is in the center at the rear may be more your problem, That bearing is behind the speed control switch and behind the governor (don't discount the governor being the problem) and is attached by two 3/8th nuts and slides onto the two guide slides that hold the motor parts in place. What i have found over the years is that 1.) the studs can bend (happens but not often) 2.) the bearing which is in the center of the big aluminum housing, (Called rear bearing assembly) moves over the years and causes humming and clattering.
So what to do about it? Loosen the two nuts a turn or two (do not remove) look at the top of the the bearing assembly and you will see a metal tab (used to attach the rear cover) (make sure the bowl and beaters are not attached to the machine) now plug it in and turn it to stir speed or number 2 position, put your finger on top of the tab and press down while the mixer is running, you should hear a change in pitch, and it should effect the clattering noise, (It will go up or down, or you may hear a new noise a light humming) (The humming is caused by the armature no longer in the center of the motor field and getting to close to the stator of the motor while it is operating, when it is out of center the developed magnetic field that causes the armature to turn gives off the humming noise because it is out of center or balance) if you notice that the clattering gets louder or softer by pushing down or pulling up you have to play with it to find the sweet spot, when you find it tighten the two nuts down just enough to hold it in place and no more. It takes a while and you wont hurt the machine but never go above speed two while doing this. If that fixes the problem you may have to do it more than once as the machine continues to age or if you move the machine around a lot. the real problem is the armature needs replacing (if this is the problem). Next you may have the machine timed wrong and that has to do with the speed control switch entirely, let us know what you find if these are not the problems we have a ways to go but they are the usual culprits with your symtom.
Feb 21, 2013 | KitchenAid K5SS Heavy Duty Commercial...
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
The mixer makes noise at stir speed. If I press down on the black contact plate at the rear of the mixer, the grinding goes away. I am not sure if it is the rear motor bearing or something else.
Hi,motor bearing usually worn out if you dont put grease on it.try also to check screws it might loosen up.Bearing might as well not contacted with the upper surface does it makes noise.Screw and bolts might as well loosen .Hope this helps.
Jun 21, 2011 | KitchenAid K45SS Classic Stand Mixer
Have a KS55 mixer that has never been used -- sitting for about 4 years and went to turn it on and it makes a noticeable clicking sound in the lower speed settings (1-3). Noise goes away (or is not...
A lot of things can happen to a piece of machinery after 4 years of idling time.
Dust, moisture, rust and dry hard Grease are just few of the problems. The
good news is it's not hard to put it back into service again. Obtain a copy
of the Repair Part List from Kitchenaid.com and start opening up the mixer.
Vacuum all dust inside, remove dirt and debris. Open up the Transmission
Housing and scoop out of the old grease. Use fresh Kitchenaid Food Grade
Grease for all gears including the Agitator (part of the Planetary Assembly) and
you are good to go.
Jun 09, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen Aid Mixer leaking grease around beater shaf
yes there are still pars avalible. the model will change but the internal parts are the same for the most part. there are screws on the back of the mixer. two on the metal band and one on the top of the motor houseing. open the mixer up you may want to disconect it from the base of the stand. to do this. see where greese is comming from. i dont think that it has a gasket you will see the gears and lots of grease you can take you finger and re smear the grease on the gears. but unfortunatly you may never get rid of the new noise. mine has been grinding for years. i use it 2 to 3 time a week. it works fine except for the noise which to me is not a big deal. if you need any parts you can get them from kitchen aid I hade to replace a gear once. (making to much pasta)
but they are easy to replace.
Jun 23, 2009 | Food Mixers
Hobart N50
Some of the N50's were packed with a white grease. It tends to seperate. So the oil portion finds it's way out. It sounds like it is getting into the motor case, and is running down the inside of the column. Hobart now uses a brown clay based grease --- Darina 2.
If the amounts are small, and the mixer is not excessively noisy, I wouldn't be concerned. If you wanted to fix it, the transmission would need to be removed, cleaned, and repacked. For a Hobart tech, 3 hours labor, $45 grease, plus parts.
Jun 19, 2008 | Hobart N50 Stand Mixer
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
236 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
