Question about Delta Plumbing
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must be doing something wrong .
  • 62 Answers
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Posted on Jul 11, 2009
Can't get the handle off the faucet hex won't budge
Don't even bother. I have 3 Delta shower faucets and have run into the same issue WITH ALL 3 .
Step 1: Call Delta and have them send you replacement parts before you follow the next step (Trim sleeve, cartridge, handle)
Step 2: HACKSAW just outside the handle, right through until it snaps off.
That's the only way you will be able to access the nut.
I tried eveything - Vinegar, WD40, CLR, Banging, Jiggling...
Problem: The brass nipple on the cartridge will fuse with the metal on the handle. Alternately, so does the Allen Key screw. They will not release no matter how hard you try.
I called Delta and they confirmed that the two metals will fuse together over time (a short period of time, in my case), but it's not a fault design but the water. Their solution (moving forward) is to wrap the brass nipple with Teflon Tape before attaching the handle, so that the 2 metals won't make contact.
However, one would think that Delta would rectify this issue. Say by enclosing a thin plastic cap that seats over the brass nipple, or better yet, pre-coat the inside of the handle themselves?
Regardless, don't expend too much energy. If you can't loosen anything,
HACKSAW RIGHT THROUGH THE TRIM SLEEVE AND BRASS NIPPLE OF THE CARTRIDGE and snap it off to access the cartridge nut.
Apr 01, 2012 | Delta & Single Handle Shower Faucet
We purchased a home built in 2001 that has the dual handle Delta Monitor 2300 series. Though this particular model, I believe, is designed to prevent this problem, my daughters are practically scalded...
There is probably mineral or rust deposits in the cartridge. Shut the water off and remove the handle and then the faceplate and remove the cartridges. Tap the cartridges and see if any debris comes out. You can try cleaning it out buy soaking it in a bowl of warm white vinegar. Keep moving it around and keep flushing the inside of the cartridge out and tapping it. There is usually a small check valve in the cartridge and you should here it rattle. With the cartridges out turn on the water supply for a few seconds to flush out the pipes. Then try reinstalling them or while they are out; go to your local plumbing supply or Home Depot or similar and purchase some replacement cartridges.
Thanks for using FixYa
Jun 20, 2011 | Delta Faucet Company RP26755 Sleeve...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
2-handle faucet handles both rotate "on" counter=clockwise
Here's the solution from Delta:
On a two-handle kitchen or lavatory faucet, if the handles rotate in the wrong direction, simply rotate the right stem stop assembly 180 degrees. This will change the rotation of the handle to the other direction.
Jun 23, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
I installed Delta shower faucet 132900 and I could not shut the water. What did I do wrong?
Did you solder the valve in? If so you may have got it to hot. Or debris could have gotten in the valve. Turn the water off, remove the handle and cartridge. Check cartridge for damage or debris
Mar 03, 2009 | Delta & Single Handle Shower Faucet
Plumbing Logo
396 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
