Question about Brother IntelliFax-2820 Laser Fax
Displays message-Close Back Cover. All covers closed.
Same problem Glasspro describes. Machine has worked without a hitch for about two years. I have unplugged for two days, blown out dust, and checked door latches. I've looked for a door sensor but can't find one.
    Problem Solver:
  • 16 Answers
Did you had a paper jam at back before this happened
Posted on Jun 30, 2009
My printer error message is close rear cover how to fix it?
Check the rear cover on the back of the machine and make certain it's closed. I've found that sometimes a small piece of paper is stuck back there and causes this problem (I have a Brother printer). In any case, the back cover is not closed properly.
Jun 16, 2017 | PRINTER Office Equipment & Supplies
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
How do I change the print head on a Xerox 8500?
How to remove a printhead
  1. Press the on-line / off-line key on the printer operator panel to set the printer off-line.
  2. Use the upper softkeys to scroll to the 'Replace printhead' card
  3. Press the softkey below the 'Replace printhead' card to enter the wizard.
    An introduction screen displays the message 'Use this wizard to replace printheads. A roll is needed for calibration.'
  4. Press the key for 'Next'.
    The screen displays the message 'Select roll to use'.
    The system does a calibration at the end of the wizard. You can only calibrate on the defined media types. When calibration is not possible with the media available on the printer, the system asks you to load the correct media. When calibration is possible with one of the rolls, the system automatically uses the correct media roll. When calibration is possible with both rolls, use the lower softkeys to select the roll to use.
  5. Press the key for 'Next'.
    The screen displays the message 'Carriage moving to centre position...' while the carriage moves to the centre.
    The screen displays 'Open top cover.'
  6. Open the top cover. The screen displays the message 'Replace printheads' and the printheads that you must replace. Find the correct printhead number on the printhead carriage.
  7. Press the front of the printhead cover to unlock the cover.
  8. Open the printhead cover.
  9. Pull out the printhead and remove it.
How to place a printhead
  1. Remove the protective tape from the new printhead.
    Do not touch the contact and nozzle areas of the printhead after you remove the protective tape.
  2. Place the new printhead in the printhead holder.
    The printhead only fits in one way.
  3. Close the printhead cover.
  4. After you replaced the defective printhead, press the softkey for 'Next'
  5. The screen displays the message 'Make sure that all head covers are properly positioned.'
    Press the key for 'Done'.
    The screen displays the message 'Close top cover.'
  6. Close the top cover.
    The screen displays the message 'Carriage moving to home position...'
  7. The screen displays 'Calibrating...'.
    The calibration process takes several minutes.
    You can stop the calibration process at any time. Press the key for 'Cancel' to stop the calibration process.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 08, 2009 | Xerox Phaser 8550DX Laser Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Close front cover message
Well here is what I can tell you.
Open the front cover. Staring you right in the face should be a bar code/number sticker. Look forward from that and there shoule be a small plastic tab, about a half inch long and less then the thickness of a popsicle stick. It is the front cover interlock switch actuator. It may be broken off.
Or look for the opening where that tab should slide into the machine the switch may be dislogded or broken.
Probably that tab has broken off not actuating the switch on that cover.
Dec 29, 2007 | Xerox Phaser 8500/DN Printer
Brother IntelliFax-2820 Laser Fax Logo
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
