Question about Nokia 6070 Cellular Phone
I forget my restore factory setting & security key guard
The other thing also i down load the nokia pc suite but i can not use usb
  • 157 Answers
Here is the Calculator link
Just put your imei number in to box and calculate !
Check IMEI : *#06#
In case of the calculator does not support your model !
You have to take some place where people unlock mobile phones !
Best Regards
Posted on Jun 25, 2009
Formate nokia310
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311.
#Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
  1. Make sure the Nokia Asha 311 on and standby
  2. Go to menu Setting, then choose restore factory setting > settings only
  3. It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
  1. Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
  2. You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
  1. Type in the phone : *#7780#
Jul 31, 2013 | Electronics - Others
I am forget my nokia6300 factory restore code
Hello You can easily generate the current with help of one simple trick.So,follow this link How to Generate Your Phone Security code..Only for Nokia bb5.First thing you need to collect Nokia USB cable which will suite to 6300.After you got the current code you can restore the phone by typing *#7780# when the phone is in standby mode and enter the generated code.Good luck
Jul 06, 2012 | Nokia 6300 Cell Phone
How to reformat nokia 5130 c-2 with the security keyguard forgotten
Follow this procedure to generate your security code.This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.3.Extract [ANT] Simple ] and run Simple.exe located in the folder4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.5.After you've connected your phone, Click "Read Info"6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below7. Nowclick on the SERVICE tab and click on GET button under USER CODE8. Your security code should now be displayed on the right side of the application window. After all format it by selecting "Restore All" from your phone setting.Thanks For visiting Fixya
Feb 27, 2012 | Nokia 5130 Cellular Phone
I changed the security code of nokia 2700 classic and now i dont remind the security code of my phone . so can you please suggest me how to change the security code if i forget
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Symbian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you don't understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Oct 31, 2011 | Nokia Classic 2700 Cell Phone
How can I Reset Factory Setting for my Nokia 5130c-2? my serial no. is 354179031338712
Hi, First open Menu >>> setting >> Restore Factory Setting >> Restore only/ Restore.If you want to reset the phone to default setting just select "Restore Only".And if you want to erase all the phone data you can select "Restore All".After this it will ask you to enter security code just enter 12345 and if not working you can generate the current by using this tricks.
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel
7. Now click on the SERVICE tab and click on GET button under USER CODE
And for details How to Generate Your Phone Security code..Only for Nokia bb5
Sep 20, 2011 | Nokia 5130 Cellular Phone
Nokia 3110 formet cod
Hello thanks for using FixYa
To format dial *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press OK. it will take some time and your handset will be format & restored to original settings.
But if you format the whole phone memory then follow the procedure below
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone will format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
See my TIP & TRICK to format Nokia Handsets which will help you out briefly
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 12, 2011 | Computers & Internet
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to...
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Jan 31, 2011 | Nokia E63 Cell Phone
How to format nokia 3200 Thanks :)
To format your cell
For soft format dial *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press OK. it will take some time and your handset will be restored to original settings.
  • Green dial key
  • Star key no *
See my TRIP & TRICK to format Nokia Handsets which will help you out briefly
Jan 23, 2011 | Nokia 3200
I forget my nokia 7210 supernova security code pls tell me wht i do ans give my email id sumit.goel.sg@gmail.com
To reset your nokia phone to factory default if you forgot the phone security code you have to follow these steps.
requirements
Data cable for your phone
Nokia pc suite installed on your system
http://www.nokia-asia.com/support/download-software/nokia-pc-suites#
Nemisis service suite -to download it go to the link below. The download would begin automatically
http://www.b-phreaks.co.uk/files/NSS/NSS103814.zip
After installing this one connect your phone and exit your pc suite tray icon.
Then open the nemisis service suite click on the tools button then select factory settings.
Then select the check box restore factory settings if your phone is symbian
then check the symbian option then select the reset button that's all
it will reset to factory default settings your security code reset to 12345.
Jun 23, 2010 | Nokia 3600
I forget my orig. phon setting...so i can't restore..ples help
Tools Required :
• Nemesis Service suite (NSS)
• Nokia PC Suite
• Data cable
Steps :
1. Connect your phone in PC Suite mode
2. Open Nemesis Service suite (NSS)
3. Then click on scan for new devices button (top right hand side)
4. Click on phone info button.
5. Now Click on Scan.
6. Select Permanent Memory.
7. Click on Read.
8. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\<IMEI>.pm
9. Open the .pm file using Notepad.
10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
11. Like 5=31313131310000000000
12. Remove all “3” digit and it will be 31313131310000000000
13. 11111 is your security code.
14. Done!!
Once you find the security code you can restore the settings by "Restore factory settings" option. Rate me if it is helpfull!!
Aug 19, 2009 | Nokia 7610
Nokia 6070 Cellular Phone Logo
99 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
