I have a Umax 2500 scanner . I need specifications for the ac/dc adapter for it. what dc voltage I need to input?
  • 508 Answers
Google it
Posted on Jun 25, 2009
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
DC to AC power cord Do they still make them if so under what name or product name?
"DC to AC" cords are not really a common item. They are called "Inverters". Typical inverters are 12VDC to 120VAC and are found in mobile applications to operate houshold current type (120VAC) devices. Inverters cost many times more than thier "AC to DC" or "AC to AC" sisters.
An "AC to DC" and "AC to AC" cord however, is a very common item. They are usually called simply "AC Adapters" and are sold in many electronics stores (Best Buy, Fry's, etc.) and electronic specialty stores (Radio Shack) and electrnics suppliers (MCM, etc.) Nearly all of them are designed to reduce the voltage in your home (120 VAC volts alternating current) to a different but usually lower voltage that is either AC or DC.
In order to select the proper AC adapter, you need to know:
(1) Input Voltage - this is the outlet voltage - often 120 volts in N. America, (2) Output voltage - this is the voltage the device needs and is often indicated near the jack, The adapted must match this voltage. (3) the device voltage type - this will be either AC or DC. The adapter must match the type as they are NOT interchangeable. (4) the size and type plug on the cord that will allow it to mate properly with the jack. There are many, many types and it should be tested for fit prior to plugging in and must match the device jack (5) the power requirements - this is usually shown as a number in Watts (w) and / or Amps (a). It is very important that the apdapter power rating is equal to or greater than the amount specified by the device. Failure to meet the requirements above can cause failure of the device, adapter or both.
I hope this helps and good luck!
Feb 08, 2013 | Uniden BC60XLT-1 Handheld Scanner
Hi I want to purchase a AC DC 12watt Power Adapter for my old ARTEC 1236P Scanner. Can someone tell me if I can use my spare Input 230V ~ 50Hz 9W (Output - 12 to 9v) adapter? If not what should be the...
This will mean the input on the first device is 120 V and input on the 2nd device is 230 V. Right? If so Yes you can use this if it belongs to the same scanner however you will have to plug the power into a 230 V Circuit. You cannot adjust, manipulate, change the Volts/Watts/Amps under any conditions. If the 203 V (Out put) plug is the same as the 120 V plug and there is a place to plug it in to the scanner then go for it. Volts/Amps/Wwatts/AC/DC are very specific to a specific device.
Jul 24, 2011 | Artronix Technology Artec 1236 P Flatbed...
I need the powers cables is an escanner model umax astra 1220p
i fyou are unable to find one for this unit i would suggest trying a walmart, kmart or radio shack for a universal dc adapter that can supply the correct voltage to the unit. they also come with universal ends. cost aroudn 20-40$USD.
your best bet these days it to buy a new scanner.
Feb 12, 2010 | Umax Office Equipment & Supplies
What does umax astra 3400 scanner power adapter looks like/
who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
Jan 13, 2009 | Umax Astra 3400 Flatbed Scanner
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
Power input
12 watts.
If you want to know more of the specifications in this flatbed scanner visit this link.
http://www.umax.com/support/knowledge/specifications.jsp?model=Astra+2000P
Jan 09, 2009 | Umax Astra 2000P Flatbed Scanner
I have a replacement universal AC/DC adapter for my scanner ...
This should be shown right next to the jack on the unit as well as the voltage. If not it should be in the user manual.
Dec 19, 2008 | Umax Astra 1220U Flatbed Scanner
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
AC Hookup
The Polarity is moulded into the plug with + or - sign to centre pin and shell as appropriate- Usually also on the Scanner cvasing near the DC input socket.
Dec 31, 2007 | Umax Astra 610P Flatbed Scanner
k24674
jasbo
jasbo
