Ca i ask what is the main cause of dead power supply on computers
Ca i ask what is the main cause of dead power supply on personal computers??
we have so may computer power supply that won't work, can you give me some tips on how to bring it ON and become useful
can you give the components that are causes the trouble
  • 508 Answers
Dust
Posted on Jun 25, 2009
I have dell 'DHS' model ,but my cpu is not working. when i give power supply to cpu that time fan are moving for 5sec after that it's not working.i have checked power supply,power cable, PSU shorts),PSU...
old post. PC is 16 years old today, (junk and not worth $10 used)
1: run it on line power only main battery out. now.
runs now,yhes, then the battery was shorted, get new one.
or run on AC only for ever.
2: RTC coin cell is dead, buy a new one and put it in.
no RTC COIN lasted 16 years, not a single one, impossible!!!
so get rid of this old coin cell., buy a new one, spend $2
3: Now the CPU fan works, and stays on, in some BIOS you can check a box say fan is always , on do so and now it only changes speed. if the fan is dead still then it may be bad. this old easy.
4: CPU overheat, I have never seen any CPU to heatsink
thermal compound last for 16 years, (mine does but not yours)
I use very top quality thermal grease (compound, no aging) ask.
5: The Power pack can be bad. (if PC dead with main battery out the pack can in fact be just bad.
6: is the screen 100% black at all times? no text ever?
most PC this old the CCLF back lamps are dead.
that is why most PC this old are worth nothing until year 2010 made. a fact. get a newer PC with LED back lamps.
ask for advice on this, have lots.
My posts can be all wrong ,after all I can not watch your screen
and do simple tests.
but the fan dead is very very serious matter.
I even strip off all modules in the Laptop, to prove there are no shorted modules in the PC. shorts cause power to shut of.
BY DESIGN.
Dec 31, 2017 | Dell Inspiron 1420 Notebook
Along the top of the picture on the screen is green, how can we get rid of this please.
You are saying about a horizontal green belt acorss the screen at the top. It can be due to main power supply [regulated power supply inside your tv]. Check it whether proper power supply is there or not. Normall it shuld be between 110 to120VDC. Different manufactures have different operating voltages. You should refer to the schematic digram of your tv.
An other cause ca be the lack of voltage, or improper voltage to vertical output section. I thing that you haven't replaced the deflection yoke of your tv till now. If deflection yoke have been replaced, convergence assembly at the neck of the picture tube should be aligned properly to rectify this probelm. Contact an experienced service personal. Ok.
Oct 18, 2010 | Audiovox Televison & Video
Ater the electric company spiked my house I am left with a CAL cl-15 blowing fuses and a Classe CA-201 with a dead left channel. Any thoughts?
Anything that blows a fuse has an overload caused by a faulty part. The suspects are the transformer, rectifier, voltage regulator and the large Electrolitic capacitors - all in the power supply section. In amps the devices on the heat sink can cause the fuse to blow.
Again the main suspect in the dead left device is also whatever is on the heat sink. However if can't hear any music etc playing even at full volume on the left you could have lost the left pre-amp stage, but I myself would stick to whatever is on the heat sink as the cause of the trouble.
Dec 05, 2009 | Audio Players & Recorders
Had my tv looked at by a technician and they said it needed a new main power supply,it was to expensive to fix so i bought a power supply and instaled it but it dont work what can i do
Usually there is a warranty period like 30 days.Ask for a replacement if that dont work either there is another problem goin on.Then just ask for your money back,there is sometimes a restocking fee.
Oct 22, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Unit is dead ...
I have seen that model have bad capacitors on the power supply which will cause that symptom. Replacement parts are very hard to come by for Polaroid TVs, But I can post a link which may be able to locate or rebuild your power supply for you. Just leave them a email with your model number and symptom. Heres the link.
http://servicemanuals.vstore.ca/
Apr 22, 2009 | Televison & Video
I have a NEC lcd1765 monitor that is dead!
Hi...there,
No power...usually caused by burnt out capacitors in the built-in power supply with inverter.
Dec 06, 2008 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Apple g4 digital audio Power supply API-9841
Solution: Replace power supply with a new one. Anything else might cause equipment damage, personal injury or death.
Any attempt for component level repair is not for the novice tinkerer. remember, opening the power supply might kill you.
My suggestion is to have the failed power supply module replaced with a brand new supply by a qualified repair technician.
Jul 24, 2008 | Apple G5 Case with Power Supply (p/n...
Busted component
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Jul 07, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Dead mother board
The problem with power surges, or low power (brownouts) causing excessive current draw can cause multiple problems to motherboards. Even if you were to pinpoint and repair one problem that appeared to fix the fault, several other components on the board may have been weakened, and prone to fail.
If you are certain that the power supply is 100% ok, then replace the MB.
The best power protection is to use a UPS.
Jan 05, 2008 | Intel Motherboard
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
