I refilled the 3472A (yellow) cartrdige in HP 3600 and showing the indication 10.92.03 and not working, please advice to solve this...
  • 508 Answers
Bad chip in cartridge
Posted on Jun 25, 2009
Get rid of the error message "toner empty stop" after replacing the cartridge with a new Samsung cartridge?
After replacement with OEM cartridge it will never show Toner empty
however refil cartrdige will show the same , You need to replace the chip to remove the empty indication
Oct 01, 2014 | Samsung Office Equipment & Supplies
My Hp printer does not want to accept refilled ink cartridges
HP printers might work and might not work with refilled cartrdiges. You can use it but will create a problem in future and quality of printing will not be good. If still you wish to use refilled cartridge then please tell the name of the printer. If your printer hardware gets damaged because of using refilled cartridges then even if your printer is in warranty hp will not replace it.
Feb 25, 2011 | HP Office Equipment & Supplies
Hp d24610 on/off button is blinking not printing
Check out http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00866324&product=2510767
try changing your cartrdige. Refilled cartridge may not work. Blinking power button usually indicates out of ink.
Nov 01, 2010 | HP Deskjet 2460 InkJet Printer
Hello. I have HP photosmart C5180 and I only need black colour to print some documents, I bought the original HP ink, but my printer says that I need to change expired colours too (pink, blue, cyan...) but...
Your model is a Inkjet printer working on HP TIJ 4.0 technology4. So it cannot work with one valid cartridge. You have to replace all of them to make you printer to work. This is what HP advices and highly recommends.
The Ink cartrdige can be bypassed only in Laserjet printers
Oct 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
I refilled my dell ink cartridges from Costco. Now my computer says "Low ink warning" How do I do a hard reset for the Dell 926 AIO Printer?
The ink is fine in the cartridge. The ink level indicator just thinks the cartrdige is still empty. You can ignore the message or turn it off all together. Just bring in your cartrdige for a refill when it shows signs of fading or streaking. Go to www.inkjet411.com for more help
Mar 10, 2010 | Dell 962 Photo All-In-One InkJet Printer
How do i re-fill my black ink cartridge
hp cartrdiges come with a coper circuit, refilling the cartrdiges might not work
Sep 26, 2009 | Office Equipment & Supplies
Ink cartridge leaked inside of my printer, how to best clean it & why would it?
It is very unlikely that the cartrdige actaully leaked*, more likely what you see is the service station area on the right side of most HP inkjet printers. It is normal for ink to be spit into this area to keep the nozzles healthy. If this is the case it is best to just leave it alone, the service station was designed to collect the ink. If there is a ***** of ink high enough that the top is scraped flat by the service station you could remove it carefully with a plastic spoon. To minimize ink in the service station follow a few guidelines: 1. Do not use an external power strip to turn off the power to teh printer. The printer should always be plugged into a live outlet. Using an external switch will result in the pritner losing track of the time since the last print job, with the result it will use more ink in servicing. 2. Do not run unnecessary cleaning cycles from the maintenance panel. A typical cartrdige would need one or less user initiated cleaning cycles during its life. Users that do a cleaning every day or even once a week expend ink unnecessarily in the service area.
If you have an older Deskjet 800 or 1000 series printer the following may apply.
For more details applicable to your situation please indicate which printer model you have, whether your cartridges are original or refill/reman and also wa tte nature of the leak is.
* If you are using OEM cartrdiges. If you are refilling it is possible to overfill or otherwise cause the cartrdiges to leak.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 01, 2008 | HP Office Equipment & Supplies
HP leaser jet 3600 doesnot print yellow
Clean the toner contacts in the printer
May 15, 2008 | HP LaserJet 3600n Printer
Printer Toolbox Not Recognizing New Black Ink
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards,
Bob Headrick, Micosoft MVP Printing/Imaging
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
Computers & Internet Logo
Alun Cox
David Payne
David Payne
