Question about Jet Tech Systems STEALTH Dishwasher
How do you check to see if the dishwasher has power?
  • 508 Answers
Follow cord open acces panel carefully test then go past power supply!
Posted on Jun 25, 2009
No power lg dishwasher
A large dishwasher should have a dedicated circuit breaker in the circuit breaker panel, check to see if the breaker is on, tripped, or off, it should be on. If it is on, remove the panel cover and check for power coming out of the circuit breaker, if there is power coming out of the circuit breaker, check for power at the dish washer. Checking for power at the dishwasher may involve pulling the connector cord if any and check the power outlet for power, if there is no power outlet and the dishwasher is hard wired into an electric box, the electric box needs to be opened and the wires need to be tested for power, involving removing the wire splice nuts or wire nuts. Once the power is verified to the dishwasher and the washer is still with no power, a fuse should be sought inside the dishwasher control panel or that the power feed wires are properly spliced. A voltage testor is needed to test for power. electric shock hazard on live wires, please be carefull or call out a electrician or handyman if power testing skill is questionable.
Aug 11, 2012 | LG Dishwashers
Whirlpool adg 7540 no power
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 25, 2009 | Whirlpool 24 in. ADG7540 Built-in...
DISHWASHER WONT POWER UP
2. Door switch
3. Timer
4. Selector switch
Jul 13, 2009 | Dishwashers
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Kenmore dishwasher no power
Check the following areas for faults.
2. Door switch
3. Timer or control board
4. Selector switch
Jun 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher has no power
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Jul 03, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Westinghhouse 907 dishwasher Sydney Australia
Nov 03, 2007 | Westinghouse 24 in. MDP531 RF...
Jet Tech Systems STEALTH Dishwasher Logo
62 people viewed this question
Top Jet Dishwashers Experts
robert
martin williams
martin williams
Level 1 Expert
Are you a Jet Dishwasher Expert? Answer questions, earn points and help others
