Question about Konica Minolta DiMAGE Z2 Digital Camera
Digital camera Battery shutter problem.
Battery box lid not getting locked .It was a slightly difficult problem.Now it doesnot get locked at all. Rest of the functions are at its best of working. Please suggest me the best solution. My son has purchased it for me somewhere in oct 2006.You can suggest me service center inMumbai,India I tried to use Doctors bandage to fix the shutter temporarily. Now it is not in use.
    Problem Solver:
  • 6 Answers
I'll sell you my battery door and supply you instructions for its installation.
keithtracypierce at
Posted on Mar 26, 2008
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
Oct 11, 2008 | Mamiya Cameras
After using our e-520 for about a year we have a problem. After taking a photo. When looking though the view finder all is black, as is the screen when switching to the lcd. Is it possible the shutter is...
digital cameras do have a "shutter", kind of. IT is electronic, just powers on/of the sensor that captrures the image. Some digital cameras have regular swhutter also, that makes it possible to get real fast shutter speeds for flsh. Take off the lens and look inside, It is possible that the mirror is locked in the up position. Read your owners manual and see if there is a reset button for the camera. Remove the battery, tuen camera on/off switch 2-3 times,replace battery and look again. Try reset switch(if available). My Nikon has a mirror locxk up function available throough its menu. Read your owners manual and see if you have the same. If you can reead menu on LCD, and manual says you have mirror lockup, then try changing settings.
Oct 26, 2010 | Olympus E-520 Digital Camera
Minolta X 300 camera On replacing batteries
on this camera can you lock shutter button down?
may have moved it changing battery.
take out battery may release it
is battery up the right way?
Feb 15, 2010 | Minolta Photography
NikonD70 digital camera
You don't give much info but I'll assume you have a Nikon D70 'cos that's where you posted your question...1. Battery needs to be charged first. Get a cheap EN-EL3 battery and charger from eBay if you need these. 2. Put a Compact Flash (CF) card in. The camera locks the shutter if there is no card (to avoid the embarrassment of shooting all day and losing your images). CF cards themselves do not have locks. 3. If you just want to test the camera with no card you can enable this in one of the camera settings menus. Press the "Menu" button on the back, navigate to the pencil icon and find item 6 (I think). It is called "NO CF CARD" and the options are: LOCK or RELEASE shutter. 4. Of course you do know you need to turn the camera on first...? Turn the little black rotary button/ring around the silver shutter release button.
Apr 10, 2009 | Nikon D70s Digital Camera
Canon A710
I have found that the camera is sensitive to battery power in that a slight fall off in voltage causes the problem. I came across a site, which I have not been able to find again, where it was stated that the contacts on the lid do not sit with sufficient pressure on the batteries to get a good contact. If you put the batteries in and look across the top, in my case, the battery +ve terminal is sitting slightly lower than the –ve battery terminal. To solve it, put a small piece of very thin plastic under the +ve contact on the lid so that it sits more proud. This has certainly improved my problem to the extent that this week the plastic fell out and the problem returned. Also I always use high capacity re-chargeable batteries. Hope this helps.
Jun 30, 2008 | Canon PowerShot A710 IS Digital Camera
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
The shutter is in the lens. Do you mean the mirror? If the mirror is locked up, was it done by selecting "Sensor Cleaning"? If so, it could be as simple as removing the battery.
Nov 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Battery Problem after very few Photos
Very likely Take batteries out and with the eraser at the end of the pencil gently polish the contacts. Do the same with the lid contacts plate. Close it and try. If it will only work with the lid being pressed try this Take a piece of foil and lay it across the batteries then close the lid this will help pack out the contact. BE careful however if the contact plate covers 4 batteries and is in two pieces make sure there are two separate pieces and do not let them touch
Jun 07, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Can't get my camera to turn on
Try rechargable batteries or Duracell. Other batteries may not have sufficient charge.
Aug 24, 2006 | Pentax Optio S40 Digital Camera
Konica Minolta DiMAGE Z2 Digital Camera Logo
49 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
