Question about Dell OptiPlex GX280 PC Desktop
I have Dell GX280,I got the Solid Yellow light on the power swicth. Monitor is still dark and blinking the power light of monitor. Anybody can help?
  • abitaz10 Jun 25, 2009
    Friend I have checked the all related connections while checked the all voltages.
  • 508 Answers
Check connection on computer!!!
Posted on Jun 25, 2009
  • Aaron Tonning Jun 25, 2009
    try another monitor to issolate problem
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Dell GX280 Optiplex wont start
Dell GX280 has been known to have issues with mother board because of bad capacitors that were sent out in them at that time. I have had so many issues with them when i working as an it. If you can open up your pc and look on mother board for expanded capacitors or even leaking. if they are not round it means that is the problem. Dells are very easy to open. On top and bottom there are kinda buttons u can press and just open towards the side that has lock for like locker lock and look inside.
Dec 28, 2009 | Computers & Internet
Dark display about 1h. when swicth on.help me pls.........
I'm going through the same thing with a Dell 1905FP - it has 3 bulging capacitors on the Power Supply/Inverter board, and I suspect they are the culprits. At first it delayed a few seconds to start (green power light flashing in all situation), then it took about 10 minutes, then delayed about 45 minutes, then went all the way to about 6 hours - all within a week. When it did come up after the delay, it was perfect. Now it won't come up at all....
It's out of warranty, Dell will have nothing to do with replacing this common failing board, and the replacement board is $50 from an online LCD repair shop.
I'm trying the capacitor replacement tomorrow - they're about 25 cents each... it's worth a try.
Jun 04, 2009 | LG Flatron 775FT 17" CRT Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Montior wont turn on
Solid Amber Power LED is indicative of a Motherboard failure. Replace the motherboard.
The GX280 is one of many motherboards made during that time period that may have had capacitors that could fail due to a manufacturing defect if the capacitor. Check the capacitors on the motherboard to see if the tops are popped (there is a X engraved across the top of each capacitor, it the X is open, then the capacitor is bad.)
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Aug 14, 2008 | Dell E173FP 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Dell OptiPlex GX280 PC Desktop Logo
636 people viewed this question
Alun Cox
