Question about AdobeAir Evaporative Cooler Direct Drive
I need a new valve/floater but no place seems to carry the right size for my AdobeAir Evap Cooler, Model ES830E, Serial J03280314. The connector is larger than most but doesn't seem to be the standard, is it 1/8'' or 3/8''? I can't remember bc it was a week ago. But, whichever one Home Depot told me it was, they didn't have one that size. They had a black floater that appeared to be the correct size until I looked more closely and saw that mine still had a larger opening than the black one, meaning where it connects to the copper pipe. Help! I just need to buy this part but don't know where to get it!!!! Home Depot doesn't have the right size and neither does a pool supply store. I can't use the swamp effectively bc the floater isn't working so the water is just overflowing and flooding my rocks and neighbors yard. I also can't seem to be able to find a working AdobeAir number to call them directly for the part. Thanks!
    President:
  • 3,433 Answers
Use a small juice plastic bottle, running the rod through the cap.
Posted on Jun 25, 2009
  • Ned C Cook
    Ned C Cook Jun 25, 2009
ADOBEAIR MODEL # P400B NEED MEDIA PAD
I have a adobe air model rw 4500 need side to hold pad.
Jul 31, 2011 | AdobeAir Mobile Swamp Evaporative Air...
The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How to clean water tank
Go to Lowes-Home Depot-Ace Hardware. In the evap cooler section they'll have a bottle of scale remover for sale. Just follow the directions on the bottle.
Aug 11, 2010 | AdobeAir WisperCool MMB8 Portable Air...
Does it need to be cleaned, if so. how is that done? AdobeAir /Mastercool model P700 serial number B150809633
Yes, it needs to be cleaned. Go to your local home store and (in the evap cooler section) pick up a bottle of evap cleaner/scale remover. Just follow the directions on the bottle. It will last MUCH longer with proper care and cleaning.
Jul 06, 2010 | Mastercool Portable Air Conditioner
Po446 evap vent code where is the evap vent located
Some might have an ses p0446, evap emissions vent circuit low. If you take it to the dealer they want 300-400.00 to fix the problem. GM has a service bulletin on this condition and have the updated part for 180.00, thats suppose to eliminate this issue.
Basically the problem is, the evap purge vent valve gets clogged with dirt, especially if the truck is used in dirty conditions. Well I figured there had to be a cheaper way to cure this problem.
Here it is:
1) find the location of the vent valve; its under the truck, locate the charcoal canister on the front of the gas tank and trace the vent line to the vent valve.
2) Take the bracket loose with a 5/8 wrench.
3) Spin the valve around so the side with the hole is facing you.
4) Take an air compressor and blow the vent valve out.
5) reinstall and clear the code and it's fixed.
Now I know the updated part from gm is supposed to keep the valve from clogging ever again, but why spend the money when all you have to do is blow out the vent valve every 50k-100kmi and save your $$$!
Subject: DTC P0446 (Restricted/Blocked EVAP Vent Path) Set, Service Engine Soon (SES) Lamp Illuminated (Replace Hose/Evaporative Emission (EVAP) Canister Vent Asm) #02-06-04-037A - (02/02/2005)
Models:
- 1999-2003 Chevrolet Silverado Models
- 1999-2003 GMC Sierra Models
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 02-06-04-037 (Section 06 -- Engine/Propulsion System).
Condition
Some customers whose vehicles are operated in dusty type environments, such as farming or mining off-road type applications, may comment about the illumination of the instrument panel SES light, with a DTC of P0446 (Restricted/Blocked EVAP Vent Path) being set.
Cause
Dirt and dust intrusion into the EVAP canister vent hose assembly, resulting in restricted air flow, may cause this condition.
Part Number 15086429 Hose Asm-Evap Emis Cnstr Vent
Removal & Installation
Purge Solenoid Valve-2.2L (L61) Engine
  1. Disconnect the evaporative emission (EVAP) canister purge valve harness connector.
  2. Disconnect the vacuum pipe from the EVAP canister purge valve.
  3. Disconnect the purge pipe from the EVAP canister purge valve.
  4. Remove the EVAP canister purge valve and bracket.
  5. Remove the EVAP canister purge valve from the purge bracket.
  6. Inspect for carbon release in the EVAP canister purge valve ports.
To install:
  1. Install the EVAP canister purge valve on to the purge bracket.
  2. Install the EVAP canister purge valve and bracket. Tighten the purge bracket nut to 71 inch lbs. (8 Nm).
  3. Connect the purge pipe to the EVAP canister purge valve.
  4. Connect the vacuum pipe to the EVAP canister purge valve.
  5. Connect the EVAP canister purge valve harness connector.
  6. Remove the air cleaner outlet resonator.
  7. Disconnect the EVAP canister purge valve harness connector.
  8. Disconnect the engine purge pipe from the EVAP canister purge valve.
  9. Disconnect the engine vacuum pipe from the EVAP canister purge valve.
  10. Remove the EVAP canister purge valve mounting bracket attaching bolt.
  11. Remove the EVAP canister purge valve along with the mounting bracket.
  12. Installation is the reverse of the removal procedure. Tighten the bracket bolts to 71 inch lbs. (8 Nm).
Purge Solenoid Valve-2.4L Engines
  1. Remove the front purge pipe from the evaporative emission (EVAP) canister purge valve.
  2. Remove the rear purge pipe from the EVAP canister purge valve.
    NOTE The EVAP canister may have released carbon particles, which caused this part to fail, and may cause damage to other components. Check the EVAP canister for loose carbon before returning the vehicle to service.
  3. Disconnect the EVAP canister purge valve electrical connector.
  4. Insert a screwdriver between the EVAP canister purge valve and the mounting bracket in order to release the lock tab.
  5. Remove the EVAP canister purge valve mounting bracket attaching nut, if replacing the bracket.
  6. Remove the bracket.
To install:
  1. Install the mounting bracket and the attaching nut for the EVAP canister purge valve. Tighten the nut to 71 inch lbs. (8 Nm).
  2. Slide the EVAP canister purge valve onto the mounting bracket. Make sure the lock tab locks the valve in place.
  3. Connect the EVAP canister purge valve electrical connector.
  4. Connect the rear purge pipe to the EVAP canister purge valve.
  5. Connect the front purge pipe to the EVAP canister purge valve.
Vent Solenoid Valve-2.2L & 2.4L Engines
  1. Raise the vehicle
  2. Loosen the EVAP canister vent valve hose clamp and slide the clamp down the hose away from the EVAP vent valve hose connection.
  3. Remove the hose from the EVAP canister vent valve.
  4. Remove the EVAP canister vent valve by placing a pry bar between the valve and mounting surface, and moving the valve forward.
  5. Remove the clip from the EVAP canister vent valve harness connector
  6. Disconnect the EVAP canister vent valve harness connector.
To install:
  1. Connect the EVAP canister vent valve harness connector
  2. Install the clip into the EVAP canister vent valve harness connector.
  3. Install the EVAP canister vent valve by pushing the mounts into the original holes.
  4. Lubricate the hose end with lubricant.
  5. Install the hose to the EVAP canister vent valve.
  6. Slide the EVAP canister vent valve hose clamp down on to the hose connection at the EVAP canister vent valve.
  7. Lower the vehicle.
Hope this help (remember commetn and rated this).
Apr 21, 2010 | 2000 GMC Jimmy
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
Does anyone know how much energy the traulsen urs48dt should be using per day/month or year? Note that the compressors in my case have moved to the garage which I assume impacted efficiency. I love the...
Ok, next question, when he replaced the compressors, did he modify the evap sections with TX Valves and remove the cap tubes? Per Traulsen specs, all remote units are factory set with TX valves while local units are equipped with cap tubes. If this modification was not done, it may be your cause of excessive electical consumption. Then again, re-reading your recent post, the compressors were changed to 3/4 hp? From Traulsen specs your unit came with a 1/6 fridge compressor and a 1/3 freezer compressor, is that correct? Electrical consumption on these are URS48DT 11.2 Amps 1/6 HP & 1/3 HP (1288 watts) at full load, while a 3/4 compressor is 14.9 amps 3/4 HP (1713.5 Watts) at full load X2 = 3527 Watts, or about 3 times original. I may be off target, but from what I can assume, I am beginning to think your compressors are over sized, drastrically and that the evap units may not have been modified to TX Valve. Let me know if this helps or if there is any additional information you can provide. Current compressor model numbers, previous compressor model numbers, complete unit model/serial number would all be a help in determining your exact specifications.
Thanks
Richard
Jun 23, 2009 | Traulsen Commercial 2 Door Cooler /...
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
AdobeAir Evaporative Cooler Direct Drive Logo
106 people viewed this question
Top AdobeAir Welding Tools Experts
Bill Boyd
Are you an AdobeAir Welding Tool Expert? Answer questions, earn points and help others
