Question about Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC F717 'C:13:01 Memory Stick Error'
I have a Sony DSC F717 with the flashing "C:13:01 Memory Stick Error" I have had the camera in for repair locally & they have cleaned & serviced it - (it is not the memory sticks, they work fine in other devices) - they are telling me that it is the main circuit board of the camera that needs replacing (which no-one can do in this state) & needs to be sent away for replacement. I have googled this on the web & have come up with a variety of solutions from formatting the memory sticks on the camera, using an eraser to clean the memory stick, inserting the MS rapidly over & over into the camera to giving the camera a hard knock or thump. All of which I have tried (although not sure how hard is hard for the knock) & none work. Have you heard of any other solutions apart from sending the camera away for a new main circuit board??
Angela
Http://www.batteringram.org/misc/f707repair/
Posted on Aug 16, 2009
  • 508 Answers
Call sony support
Posted on Jun 25, 2009
I have been using a 512MB stick for the past 7 years. I also have a 32MB stick which originally came with the camera. Both were working fine up until a couple of months ago. I tried the solution on this site : http://batteringram.org/misc/f707repair/ but it did not work. Any other suggestions for a FREE repair :)
Posted on Aug 30, 2012
2 Suggested Answers
SOURCE: dsc-f717
The Sony DSC-F717 will only take upto a 256MB Memory Stick - larger size Memory Sticks will give the C: 13:01 error. Use a correct memory stick and your camera should be fine. Regards, Andrew
Posted on Sep 01, 2010
Memory stick error
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Nov 19, 2007 | Sony Cyber-Shot DSC-F505 Digital Camera
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Sony cybershot dsc-n2
I see the same type of reports on the internet for just about all types of Sony cameras.
It can occur when a memory stick goes bad or when the camera memory stick reader has a problem.
First try a reset of the camera.
You will have to check the User's Manual to see how to do this.
Next try a new (or different) memory stick and see if you get the same bad result.
If you do, it is likely the problem is in the camera.
Sony will probably want about $200 to fix the problem.
Jan 06, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Sony DSC-P10
C:13:01 error code means memory stick/ card is unformatted or broken memory stick/ card. please format memory stick/ card, this option is available in camera menu and try again.
If problem still there, use another memory stick/ card.
May 30, 2008 | Sony Cyber-Shot DSC-P10 Digital Camera
Sony cyber-shot dsc-s30
try a different memory stick, if no problem with the new stick, use a pc to run a quick format on the old memory card... should solve the problem.
May 01, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Memory stick error
This is a problem with the battery connector inside the camera. It is common to the DSC F717 and this camera. It's, unfortunately, a pro camera repair issue on the 828. It can be fixed DIY on the 717. I did it to mine and now it works fine.
Dec 13, 2007 | Sony Cyber-Shot DSC-F828 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Format error
Try another memory stick - either a friends or take it to a store- if the camera is OK buy another stick If not - buy another camera or contact Sony for a repair/replacement estimate
Aug 21, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
1,458 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
