Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Same thing. I have the exact same problem, with the exact same monitor model. Luckily, I got the monitor free so it's not a big deal for me. Took the monitor apart and I found two of the capacitors were bulging, so it's very likely that's the problem. However, I cannot find anywhere to purchase the appropriate capacitors, so there's not much I can do... yet.
  • 1,684 Answers
If you have the 2 blown capacitors on the power board then most likely yo also have blown MOSFETs and a blown fuse. The MOSFETS and fuse blow when the capacitors short out when they blow. We sell a kit with the capacitors, MOSFETs and fuse with instructions for $10.00 plus shipping. Let me know if you need a repair kit.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 04, 2009
I need 1703fp icc profile / XP drivers
Will make this simple for you this is a free download and does the driver downloads free also, and if there are other out dsated drivers it will update them also. Pleas3e download slim drivers for free may have to make your self a free account no big deal. let it scan if it needs a driver it will fix it. Or you can go to dells website and got to there driver downloads and put in the model number and download there.
Oct 17, 2012 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
1998 honda accord will not start
Is it possiable that at some point, somebody repaired the fuel line
with a rubber hose passing it between the frame, and over time
the shocks have weakened just enough, so when you get in the car,
the fuel line is being pinched? It happened to me, took a year to find it.
Good luck
Jun 22, 2012 | 1998 Honda Accord
I have a 1 hp hayward super pump. the model # of the motor is C48K2n143B1. I need to replace the motor only. is it a big deal?
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
Sep 15, 2010 | Hayward 3/4hp Super Pump Inground Pool...
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
What's involved in replacing the stator on a 93 Vulcan 750?
Not a big deal. Just remove the left engine cover and you will find the stator bolted to it. Remove the three bolts holding the stator and the stator will then be free to come apart from the cover.
Nov 01, 2009 | 1993 kawasaki VN 750 Vulcan
Temp gauge raises quickly starting cold engine. Told it could be a coolant sensor. Is this a big deal or can I just keep monitoring my coolant level? 1995 Saturn
Any cooling system fault in JULY/AUGUST is a big deal. This sensor is 22$ and can be installed in a COLD engine in minutes.Very small cost for accurate gauge so you can monitor gauge and know if real overheating conditions exist.I would probably spring for a new thermostat while Im servicing that sensor and coolant just for good measure. stay cool
Jul 18, 2009 | 1995 Saturn Sl
Big noise when in 4x4 on corners
I'm betting you will be running into a problem I am dealing with shortly. I would advise you to check your front axles possibly the transfer case as well, luckily you can drive straight in the 4x4 mode, mine grinds as soon as i move the lever, it might not be the wheel bearings, however it could be the CV joints, and if that is the case you may want to look into swapping your axles out. I'm not a professional Jeep guy but mine has had almost every problem it can have, just some advice, hope it helps.
Mar 28, 2009 | 1996 Jeep Grand Cherokee
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Light comes on, no power to montior...
After posting my problem in this thread, I sent my Acer back in its original packaging with a copy of my receipt to Acer Technical Service. It still had a year left on its warranty (out of the original three years), and so I figured they would repair it. Much to my delight, they actually did. It took almost 3 weeks, and there was no email notification during the repair period (even though I asked about the status of my monitor once), and just when I was giving up hope, a big box arrived on my front doorstep. The note inside said:
"Enclosed you will find your unit which was sent to us for service. It has been thoroughly tested and repaired.
Repair Comments: Performed repair on customer unit.
Description: Inverter Board AA668 24TBD292LF..."
So it looks like the problem was an inverter board, which they replaced. I plugged the monitor up to my laptop again and it's been working fine all day. It was a bit hard to get in touch with Acer about the problem at first, and during the repair, but in the end they followed through and repaired the product free of charge.
Oct 01, 2007 | Acer AL2416W 24 in. LCD Television
Mag LT561 Lcd monitor
Simply try replacing ALL the large Value Electrolytic Capacitors on that board, 1000uF, 470uF, 330uF, 220uF, they are "the big fat round blue things" marked with say 1000uF 16Volt or the like, get the EXACT same ones and replace them... this may indeed fix ya uint. Good luck.
Jul 07, 2007 | Mag Innovision LT561D PNP Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
227 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
