Question about LG Televison & Video
I have a problem with LG mw-60sz12 tv Iit turn off
I have a big tv model LG mw-60sz12 it used to turn on for like few seconds and then turn off by itself now i checked the lamp , i dont know if am suppose to see a light or anything , i remove it then i put it back , now i can hear the speakers popped when i turn on the tv , but the screen never on and the buttom for the lamp is flashing green , is there any solution should i replace the lamp and wat if i replaced the lamp and the problem still the same
SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Posted on Sep 13, 2008
  • 70 Answers
SOURCE: mw-60sz12 parts
Hi there.
I am a service tech.
After reading about the this particular l.g. set i decided to llok into the optic engine and
have found that the blue polarizing lense is crook.
Believe it or not but the set will work fine if you remove this lense, alternatively if you remove the lense
and want to replace it. Go to ebay and type in hoya polarizing lense. Buy the 72 mm circular lense.
Then cut it to size and replace it .
Has fixed many of my customers sets.
Hope this helps.
Posted on Oct 15, 2008
  • 4090 Answers
SOURCE: RESET LAMP HOURS
press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
Posted on Jul 31, 2009
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: the lg tv clear middle and blue around the outside
Verificar a filtro do lcd azul, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada. Lg não fornece o filtro separadamente do conjunto óptico.
Posted on Feb 19, 2010
Problem with LG LCD TV, model MW-60SZ12. there is a yellow shadow at the middles and some blus shadow starts from the right corner and goes down to the bottom of the screen. it stays on all the time even...
We have this problem too, emailed LG Australia where we bought the TV from (heard that this was a warranty issue) and they told us to take it to an authorised repairer here in NZ. We telephoned 2 repairs (we are rural and carting a 5 foot TV about the place isn't easy) and the word is the part is no longer available and the last time the repairer undertook the work it cost over $NZ2000 to fix. We are disgusted that our very expensive TV hasn't lasted very long, nor has available parts.
Jan 16, 2011 | Televison & Video
I have an LG Rear projection TV Model No. MW-60SZ12, it has patches of blue tinge through the bottom of the screen, i have replaced the globe and the picture has improved but i still have these blue...
your optic engine is stuffed! the blue ,green & red optics are glued into place instead of screwed.after time this glue fails and the colours fade onto the screen. very common problem with this model.
Jul 20, 2010 | LG Televison & Video
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
The lg tv clear middle and blue around the outside it is an lg dlp mw-60sz12
Oct 17, 2009 | Televison & Video
My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Sep 27, 2009 | Televison & Video
I cannot find my tv ariel hole to plug my ariel in
It's not a TV but a monitor. You need an external tuner such as a satellite or freeview (in the UK) box to drive it
Jun 29, 2009 | LG Televison & Video
Blue screen lg rear projection tv mw-60sz12
Lcd rear pro MW-60Z12 turn on but it on screen says Video no signal
Jun 09, 2009 | Sony KDF-E42A10 42 in. LCD Television
Problem with LG LCD TV, model MW-60SZ12. there is a blue shadow that starts from the right corner and goes down to the bottem of the screen. it stays on all the time even on a black screen (not off)....
Verificar o filtro do lcd azul dentro do bloco óptico, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada ou manchada. Lg não fornece o filtro separadamente do conjunto óptico. Tem que trocar o conjunto óptico completo cód.: 3141VSN200B.
Sep 02, 2008 | Televison & Video
LG LCD Rear projection TV with a blue flare on the screen
Verificar o filtro do lcd azul dentro do bloco óptico, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada ou manchada. A LG não fornece o filtro separadamente do conjunto óptico. Tem que trocar o conjunto óptico completo cód.: 3141VSN200B.
Jan 01, 2008 | Televison & Video
Mw-60sz12 parts
Hi there.
Hope this helps.
Jan 01, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
159 people viewed this question
