Question about HP LaserJet 4 plus Printer
HP Laserjet 4 plus printer
I do not have the paper tray for legal size paper. Therfore, I cannot print a full page on legal size paper.
    Champion:
  • 220 Answers
Use the m/p tray.configure printer to print any size.
Posted on Jun 25, 2009
Load legal message
You will need to go into the printer's settings and change the tray 2 paper size back to letter. This printer is an oldie and does not rely on the paper tray to tell it what size paper the tray contains. Another possibility is that If your program is sending a print job (which will over-ride the printers settings) that somehow is set up as legal, then you will need to either abort or cancel the print job on the printer or install a legal size piece of paper into tray #1 (the manual feed tray) and then press GO or CONTINUE on the printer to complete the print job!
Good Luck!
Rich Lilja
Oct 28, 2013 | HP LaserJet 4 plus Printer
How do you manually feed legal paper into a HP laserjet 4 plus (model 2037A)? It only has a letter paper tray. I inherited it without a service manual
The LaserJet 4 plus I have worked with had a paper tray that was adjustable for letter or legal. If yours is not, there should be a door on the front of the printer that will pull down at the top, and is hinged on the bottom. Open the door, you will be able to extend the "paper tray" and put a small amount of legal sheets on it. Go to the menu and tell it to print to this paper tray, I believe it is paper tray one.
Aug 02, 2013 | HP LaserJet 4 plus Printer
HP Laser Jet 4 Plus + PC Load Legal
PC Load Legal means that the printer has been sent a print job formatted for legal size paper and that is not what is currently loaded into the printer's input tray. So, either change the paper to legal or cancel the job in the printer, reconfigure the document on the computer for letter (or whatever is loaded into your printer), and send the job again.
Jan 22, 2013 | HP LaserJet 4 plus Printer
Cannot print legal paper in HP laserjet 5200
Try to set in printer setting.
Select Printer-->Properties-->Advanced-->Printing Preferences-->Paper/Quality
Set it A4 Paper...
Jun 08, 2012 | HP LaserJet 5200 Printer
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
No problem, just have an email that I need to print and don't know how to set the printer up to print automatically from legal/letter size paper.
Depends on your model, you should be able to adjust the paper tray for the paper size you are wanting. Also you can go into the menu and change print settings
Jan 27, 2011 | HP LaserJet 4 plus Printer
I HAVETHE PRINTER SET ON LETTER SIZE BUT WHEN I GO TO PRINT THE PRINTER DEFAULTS ( "LEGAL TRAY EMPTY."
More than likely, the print data coming at the printer contains either a PJL Command for legal size paper or a Printer Control Code for legal.
Check the page setup on the application to make sure it is set correctly.
You can also do a "print to file" off of the printer properties page. Name the file something simple like "Legal Error" Windows will assign a ".prn" file extension to the name.
Then send the fie to me at don.farr@hotmail.com. I can verify the error is in the data file and if necessary correct it for you.
Don
Feb 06, 2010 | HP LaserJet 4 plus Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
