Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Hazy picture on my sony projection tv
How do I clean dust off of the inside of the screen
    Problem Solver:
  • 7 Answers
Compressed air ssprayed in he vents usually on the side or top of the screen if that does not work try taking the face plate of yourself if it has clasps to prevent you from opening it dont because if you break those claps it breaches any and all insurance policies you may have on your tv
Posted on Jun 25, 2009
Picture is bright and hazy, has been calbrated...... is the screen shot?
The guns and screen needs a cleaning , and also it is possible that the coolant needs change.
Feb 24, 2011 | Sony KP-53XBR45 53" Rear Projection...
The picture is almost hazy and is kinda dim. picture not bright??
have you tried to take off the front screen and clean the lens and mirrors yet? if this is a philips 9or a magnavox you will most likily need to change the fluid inside the picure tubes
May 08, 2010 | Televison & Video
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
REAR PROJECTION GREEN SCREEN
dust can cause this, keep your tv clean especially since dust gets into the little vent and can keep the heat from the bulbs from escaping. If that doesn't help let me know how long it takes to get a green screen again.
Feb 06, 2009 | Sony KV-20M10 20" TV
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
WD-62525 works fine but has hazy picture!
ISCABITTLE-TRY REMOVIG THE WHOLE FRONT SCREEN ASS'Y. AND CLEANING THE SMALL MIRROR INSIDE/BOTTOM YOU'LL SEE A HUGE DIFFERENCE-JOE TV
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
169 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
