Question about Ecoquest Breeze AT Living Air Purifier
I have a breeze AT, fan is the only one that's working, I tired to clean and visually check if there's anything out of the ordinary but nothing that I could tell, what seems to be the problem?
  • 520 Answers
Make sure the bulb and starter are working....do you see blue light emmissions from the inside of unit? That and the grid plate are the major players in this machine.clean plate,soak in ammonia and clean contact fingers that can get corroded including the female spade connectors for the wiring.
Posted on Jul 08, 2009
Came home and unit was off and cannot turn back on. No response at all. Cleaned it and still nothing happens
Check to make sure the screen is pushed down in the back to activate the failsafe button. Sometimes the button can get finicky. Take off the screen and push it down with something. See if it does anything, if not, check the fuse and the plate, if it cracks, it's blow the fuse later.
Jun 08, 2011 | Ecoquest Breeze AT Living Air Purifier
I have two ecoquest breeze and they are both around four years old. One just quit working, meaning the fan will not turn, the lights are still on, the other one the lights are all lit up but I cannot...
For the fan:
1) Unplug the machine
2) Remove the front grid.
3) Firmly but carefully pull the fan blades off of the shaft, holding toward the center of the fan, not the blades.
4) Use a light household oil (3-in-1, sewing machine, hair clipper) and put a drop or two on the shaft while you turn it manually. Do this until you feel the shaft moving easily.
5) Leaving the front of the machine open, turn it on and see if the shaft turns. If it doesn't, unplug it again, and continue working small amounts of oil down the shaft and then seeing if it turns.
6) Replace the fan. Turn the machine on, and give the fan a spin if it doesn't turn on immediately.
That should do it for that machine!
The other machine may be set on "Sanitize." This means that it will run at top capacity for 2 hours. Push the "Sanitize" button to deactivate it, then adjust the controls for daily operation. If this doesn't solve the problem, the issue is most likely with the computer system itself, and we can't do anything about that! Unfortunately, Vollara (new name for EcoQuest) no longer services or sells the Breeze. However, there are some options for upgrades and/or trade-ins. Call Customer service (800-989-2299) for options. Use #16618 if you need a referral number.
Jan 17, 2011 | Ecoquest Breeze AT Living Air Purifier
I have 5 air purifiers Ecoquest, Alpine all in need of repair, need someone in Tempe, AZ to look at them. Thanks
The problem:  EcoQuest is now Vollara, and has discontinued the sale and service on the Breeze machine.  Some of the machines may have basic problems which you can troubleshoot.
1)  If absolutely nothing happens when the machine is plugged in, check the fuse.  Replace if needed with the EXACT same size (usually available at auto parts stores).  Also check the plug, making sure it's inserted firmly and is not frayed or broken.
2)  If the machine turns on, buzzes, but the fan doesn't turn, you can remove the front grid and fan blades and oil the shaft with a light household (sewing machine or hair clipper or 3-in-1) oil.
3)  If the fan turns, but no/little purifier odor is emitted, check the plate(s).  Inspect them carefully for any flaws, cracks, loose seals, broken screen filament, discoloration, burned spots.  Any imperfect plates must be replaced.  (Call Vollara Customer Service at 800-989-2299, using #16618 as the dealer referral number.)
4)  Clean plates which show no defects.  Use a solution of ammonia/water 50/50.  DO NOT USE any kind of sudsy or scented ammonia, nor any cleaning solution which is merely ammonia-based.  DO NOT use detergent or any other cleaning product!  Use a soft brush to scrub, then rinse well.  Blow-dry or air-dry.  DO NOT USE any kind of towel or cloth to dry!  Avoid touching the screen mesh with fingers.
5)  Clean antenna ionizer (the circular metal object) and the plate contact "fingers" with a cotton-tipped swab and alcohol.
6)  Double-check to see that all parts are inserted and aligned correctly, and that there are no visible loose or corroded wires.
If none of these options works, the problem is most likely in the computerized works, and cannot be easily repaired.  Perhaps some machines can be used for parts and a knowledgeable electronics person may be able to reconstruct a couple of working machines.
You can attempt to locate a dealer near Tempe by going to www.vollara.com and entering your zip code in the "Find a dealer" link.  Or you can call the above customer service number and ask them to find a dealer for you.
Jun 07, 2010 | Ecoquest Breeze AT Living Air Purifier
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Fan won't turn, Fight just flicker
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Breeze AT Living Air Purifier
My ecoquest breeze is squeaking
Singer sewing machine oil works great. Remove the front grill and carefully remove the fan by sliding it off the shaft. Where the shaft meets th4e motor, place three or four drops of oil. Spin the shaft and wipe off the excess. Place the fan back on the shaft, flush with the end of the shaft. In the rear, remove the lint screen and the ozone plates. Put oil on one end of a Q-tip over a trash can until it drips off. On the rear of the fan motor, push the Q tip against the shaft so that oil oozes out. Again, spin the fan. Repeat this process every time you clean your Breeze and it should never squeak again.
Mar 25, 2009 | Ecoquest Breeze AT Living Air Purifier
Ionic Breeze Professional Series Table Top Model
you need to clean the unit entirely, but be prepared, it will eventually do it again and again until it finally stops working all together. I have sent three back in one year and now they won't do anything since itis longer than the 1 year warranty. No wonder theyare bacnkrupt; selling worthless ****!!
Mar 09, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
Nov 06, 2007 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
136 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
