Question about NetGear WGT624 Wireless Router
Wirless network - laptop
My wireless network is configured correctly, because I can connect to it from one laptop. But when I connect to the same network from another laptop, I can use skype, but everything else is not being connected to the network, IE, Firefox, other messengers, nothing.
There is no problem using non wireless network as well, for the same laptop
I have Win Vista, Netgear wireless router WGT624
I would appreciate any suggestions,
Thank you
  • 147 Answers
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Posted on Jun 25, 2009
How do i turn on my wifi on acer aspire 53152077?
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 04, 2012 | Acer Aspire 5100 Notebook
Cant connect to wirless network
if you can connect to your wirless AP from other devices such as mobile or other laptop this means that you have to check the following:
1- delete then re-create your wireless profile .
2- make sure that your wireless adapter is cofigured to obtain automatic ip address not static.
but if you are not able to connect with other devices , then make sure that you have the correct security password (if any) or check the configuration of your Access Point.
Feb 07, 2012 | Toshiba Satellite P105-S6197 Laptop
I reinstalled Windows XP Pro on my Dell Latitude C510 Laptop and now my wireless direct access button does not work. I also cannot see any wireless connection on this laptop. It was working before I...
Hopefully this helps
Try the following: click start, RIGHT click on My PC, click on administration, select services and applications, select Start wireless configuration service, click start service. Close the window
Open configuration of wirless network, flag the option let windows configure my wirelss network
That should let you see and select your wireless device
I have to do this everytime I start my laptop. I would like to have the system make this automatically, but I don't know how.
Oct 15, 2009 | Dell Latitude C510 Notebook
I can not access wirless connection. The system states connected but it's not connecting
check wireless network adapter is configured to get the IP adrress manualy or automatically. if it's manualy, then change the settings to automatic so that wireless network can issue an IP adress to the device.
Aug 17, 2009 | Acer Computers & Internet
Can not connect to wirless Dell 1525
Does it have awirless card or just an ethernet cable card?
Jul 28, 2009 | Dell Inspiron 1525 Notebook
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer..
3.in the windows..run the cd driver of WUSB54GSC and install...next..next...after that..restart computer...
4.in the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless internet is not working my wirless card does not work
remove network connection for wirless,
remove wireless card,
reboot,
then shut it back down,
while off reinstall wireless card then boot back up,
it should ask you to configure it.
May 02, 2008 | Computers & Internet
Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
My laptop cant find the connection
reboot the laptop make sure the w/l connection is enables>and right click on teh w/l i-con u can see on teh left side bottom corner on the laptop and select view avaliable networks(SSID) click on ur network and connect>and click on prefered net works and click on the network (SSID)>AND CLICK ON CONNECT RATE ME SOLVED IF ITS HELP FULL THX
Oct 30, 2007 | Linksys Wireless-G Broadband Router
NetGear WGT624 Wireless Router Logo
110 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
