Question about HP LaserJet 1200 Printer
HP Lasejet 1200
My printer has worked properly till yesterday, i installed a new toner and now every sheet comes out terribly smudged at the bottom right and it looks as if somthing inside is folding it upward. -the paper comes out stright but the ink config. gives the impression that its being folded
  • 417 Answers
Seem that it maybe a faulty cartridge. If installing a new cartridge does not sort the problem then there is two other things that could be causing the fault.
1 the transfer roller is out of position.
2 The fuser unit is faulty.
Please try the toner cartridge first though.
Thanks J
Posted on Jan 06, 2008
My HP LaserJet 1300 printer smudges the entire document and the toner is very faint. The cartridge has toner in it.
It means your machine needs cleaning. You can purchase cleaning sheets from the office supply store, and insert it like a regular document, hit print, and the dirt comes off.
Dec 21, 2012 | HP LaserJet 1300 Printer
We have an hp Laser Jet 1300 printer. Approx 2" from left there is a smudge line from top of printed document to the bottom where the ink in the letters is scraped off and there is ink smudged onto...
First of u refill ur toner?? if so i advise u to get a new original one and refill refill the same toner for more than 3 times. Secondly, How old is ur printer and how many pages do u print weekly..or u be better off buying a new one...Finally, I think the problem is with the heated rubber rollers that are not melting the charged toner particles causing it to smudge. try cleaning the printer by removing any dust...i prefer that u try it out with a new toner and see if u have a same problem.
May 05, 2011 | HP LaserJet 1300 Printer
Hp Lasejet 5200tn new printer ligh print Problem
Did you take the seal off the toner? Or possibly a bad toner.
-Carl, please let me know if this helps.
Jun 26, 2009 | HP LaserJet 5200tn Printer
Smudge on all printed and photocopied sheets
Check the paper path to ensure that there is no spilled toner anywhere.
Take a look at the toner drum and make sure it is clean and there is no toner leaks.
Rotate the drum with a finger (take it out of the printer) and make sure that it is not dameaged or dirty.
Jun 03, 2009 | Konica Minolta magicolor 1690MF All-In-One...
Toner smudge/how to clean?
Inside the printer there is a piece called a "blade". After a sheet is printed then the blade's job is to run across the toner cartridge and clean up all the toner. If the blade is not working properly then you will get excess toner. So the blade needs to be changed. You can change it yourself, by looking for instructions off of the internet or have a repair shop do is a website just to give you an idea of what I am talking about. Any questions let me know.
Pls rate this solution with 4 diamonds.
Apr 14, 2009 | Office Equipment & Supplies
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
Smudge mark 2-in wide down right side of each sheet of paper.
Generally speaking, any area that is darkened, is receiving less light. This can come from a lamp that is failing (similar to a fluorescent lamp used for lighting developing a dark end) or a mirror or optical lense that is contaminated with toner.
This may require some disassembly to diagnose and cure.
You may also want to visually check the fuser assembly (often accessible behind a door) to ensure there is no toner buildup on the affected side.
Mar 30, 2009 | HP LaserJet 3600n Printer
HP Laserject Printer/Copier
first u must diagnostic the problem to see if the problem from the drum unit or the fusser unit by stop the printer in the middle of print and remove the paper then u can see if the smudge appear it well be from the toner if not then the fusser faulty
Mar 26, 2008 | HP LaserJet 1200 Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
HP LaserJet 1200 Printer Logo
95 people viewed this question
Ben Johnson
