The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
ON A WKL 1060 AND FOR THAT MATTER ON ALL WKL UNITS THE E1 CODE IS NOT AN ERROR CODE ITS A FEATURE.
ON INITIAL START UP OR AFTER UNPLUGGING THE UNIT FOR MORE THAN 10 MINUTES (RESETING THE BOARD) THE UNIT WILL RUN FOR 30 MINUTES AND THEN IT WILL CHECK TEMPERATURE INSIDE THE WINE ROOM, IF THE TEMPERATURE IS 70 DEGREES OR ABOVE IT WILL DISPLAY E1 AND SHUT OFF THE UNIT. YOU WILL HAVE TO RESET THE UNIT BY UNPLUGGING IT FOR NO LESS THAN 10 MINUTES TO RESTART THE UNIT, IT WILL RUN FOR ANOTHER CYCLE OF 30 MINUTES AND IT WILL RE CHECK TEMPERATURE AGAIN, IT HAS TO READ 69 OR LOWER FOR THE UNNIT TO RUN NON STOP TILL IT MEETS THE SET COOL POINT OF 55 DEGREES.
Is this information not contained in the camera manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
reading forums on this reveals that the h9 is a 3.55 limited slip diff mainly used in f150 fords. However all that is immaterial as what you are looking for is a diff centre that is 3.55 ratio that will fit in your housing . The same housing will use the both LSD and normal diffs as the LSD was an option offered for off road vehicles or vehicles operating in bad road conditions
No idea what that code means but I have seen a lot of postings about it. It seems to originate from being dropped, is expensive to repair, but is often solved by actually whacking the camera with ones hand.
