Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Problems with winmx
I get a winmx connection but do not get any results when searching..also no one can connect to me and i can not download even though i am connected...how do i reset my router and winmx
Winmx is alive and well with a userbase of approximately a million users. All types of files are available to download. get it free at
http://patch.winmxconex.com/
Posted on Jul 27, 2009
  • 3 Answers
  • Bluey_412 Jul 27, 2009
    after you have patched with the correct patch, you may also need to adjust the port forwarding settings in your router, and adjust the timeouts in winmx settings
Go to this site to help you forward your router ports for winmx.
http://winmxworld.com/tutorials/routers_info.html
    President:
  • 1,314 Answers
The problem is WinMX is no longer in operation. No one can connect to you through winmx because the service has been shut down.
Posted on Jun 25, 2009
I have satelite L202 laptop, after a time it got a problem on the screen, when i logged on the laptop the screen even the system will be stop and the screen desplays abnormal. it can't doesn'
Sounds to me like you have a virus or infection. The fact that it works on in safe mode is the key. Most viruses need the internet connection to function, after all that is how they got into your system (by the internet). Safe Mode does not give you internet connection so the virus is handcuffed and can't function like it does in normal mode.
Boot your system as if you are going into Safe Mode but instead take the Safe Mode With Networking option (this will give you internet connectivity). Download and Install MalwareBytes then run a Quick Scan.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Apr 26, 2012 | Toshiba Computers & Internet
Internet connection/network adapter problem
If you are using the Windows own Wireless connection wizard (Wireless Zero Configuration service aka WZCSVC) this is designed to recheck every 20-30 mins for another connection this is your problem disable the service here download this tweak.
http://rapidshare.com/files/260751524/Disable.WZCSVC.reg
Then download and use the laptop NIC's own software to search for your Uni server and then connect using the WEP or PSK, this will solve your problem then create a profile in the NIC connection software and it will never forget.
LOL
Sep 27, 2009 | Acer Aspire 6930-6455 Notebook
Ares search not connecting
The cause of the issue may be the changes in the incoming connections via specific ports,
try changing the settings from the control panel especially incoming connections port no.
else try reinstalling the same with some different versions.
Jun 20, 2009 | Computers & Internet
How to connect htc p3300 mobile to pc
search google
microsoft active sync 4.5 download
first result is download page..
Apr 07, 2009 | HTC P3300 Smartphone
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Same problem
any luck from here in the faqs section
scroll down to list of help solutions Search Results - Lexmark Z605
riz.
Aug 21, 2008 | Lexmark Z600 InkJet Printer
RCA television suddenly has problems with cable reception
You have a bad ground connection somewhere. Either the cable has a break in the ground side or there is a connection problem elsewhere. Try with another cable if possible.
Dan
May 02, 2008 | Televison & Video
How do I make a primary connection with WinMX through my D-Link router?
Start up WinMX and go to Settings, then press the Setup Wizard button. When prompted to clear all previous settings, select No. Now you can click next through the screens (your previous information will still be there) until you get to this screen: Click on Cancel Test / Manually Configure. Click No. Do not use a proxy server for outgoing connections and then click Next. Enter 8888. Click Next. Enter 9999. Click Next. Finish the setup wizard. You will need to open (forward) 2 ports on your D-Link router. After you configure your router, you must restart the WinMX software. Step 1 Open your web browser and enter the IP address of your router (192.168.0.1). Enter username (admin) and your password (leave blank). Step 2 Click on Advanced and then click Virtual Server. Step 3 Create a new entry: Click Enabled. Enter a name (winmx). Private IP - Enter the IP address of the computer you are running WinMX from. Select TCP for Protocol Type Enter 8888 for both Private Port and Public Port Click Always or set a schedule. Step 4 Click Apply and then Continue. Step 5 Repeat steps 3 and 4 but name it winmx2, select UDP for Protocol Type, and enter 9999 for both Private Port and Public Port.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
