Question about LG WM2016C
My washer will not turn on. We had an uneven load a few days ago and now it will not turn back on. HELP!!
  • 47 Answers
Do you have the owners manual? Look in there for any reset info. Check to see if the circuit breaker for the power outlet popped. Try unplugging the washer and then wait a minute and plug it in. If the motor got hot it might have a reset button on it.
Posted on Jun 25, 2009
I have a Maytag Neptune front load washer that the tub is rubbing and is loud.
Could be the bearings . But it could also be the springs that center and hold tub in place. They weaken over time and it is not uncommon for a tub to be scraping because one of the springs is shot. When you replace one, you replace all at same time and eat your wheaties because they are hard to replace.
Sep 08, 2015 | Maytag Neptune MAH5500B Front Load Washer
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
Nov 17, 2014 | LG WM2455 Front Load Washer
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Please tell me how to correct error code OP. My lid is not open and it was properly working just a day ago.
press clear or cancel button ,any errors in washer can usually be fix by this. if not unplug it fro few minutes and plug it back in.
May 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Purchased a Maytag Maxima washer two weeks ago--beginning to think it's ****. Have been trying to was a load of laundry for 2 1/2 hours now and can't get the washer to spin the load dry. Have tried...
I just bought the same washer and there is a problem with the steam sensing device. Check for code in time window. mine has a F08 and E01. Repairman coming in 2 days.
Feb 18, 2011 | Maytag Washing Machines
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
Cold Water runs constantly even if the washer is off
you will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
May 01, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
LG WM2016C Logo
237 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
