Question about Platinum Computers & Internet
My platinum has completely deleted the schedule for all appointments. After a regular routine errored shut down, it told me my shortcut to platinum could no longer be found. THen it began to run like it was reloading the entire program. IT then asked for all of my information - Doctor's names, where the computer was located, etc - and now its as though Platinum was just loaded onto this computer for the first time! HELP!
  • 4 Answers
Try system restore.
Start - Programs - Accessoriews- System Tools - System Restore
To Undo the changes you did
Posted on Jun 27, 2009
Scheduling appt. at labcorp
To schedule an appointment, go to our Labs & Appointments page and search for the patient service center nearest you. Once a site is chosen, click "Schedule an Appointment" and follow the instructions.
Apr 24, 2017 | Labcorp Health & Beauty
Why does my Brother mfc 420 cn shut off and turn back in the middle of scanning
Maybe the printer needs it's software updated. You could try going to the Brother web site and check on that.
May 17, 2014 | Brother MFC 420CN All-In-One InkJet...
How often should I visit my dentist?
Most adult and children visit the dentist for regular checkups and cleanings every six months. People at greater risk should have checkups more often.
Feb 03, 2013 | Health & Beauty
I have color notes on my antroid phone & tablet, when i set up recurring task - routine - what ever you want to call it on the calender, and i ck this off when complete, it either cks all recurrin
try formating it by shutting it down... pressing vol up + power button and choose by clicking down or up vol... choose format/wife data factory... :)
Jan 19, 2013 | ASUS INTEL CORE 2 DUO T7200 2.0GHZ...
How to remove arrors from shortcuts in win xp
Problems with desktop shortcuts and icons
Shortcuts on the desktop do not work or are broken
Desktop icons are broken or have not been used in 3 months
Startup items do not work or are broken
System maintenance tasks
Free up disk space by repairing disk volume errors such as bad sectors, lost clusters, cross-linked files and directory errors click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
Free up disk space by removing error reports and troubleshooting history older than 1 month
Set the correct system time and synchronize system clock with the time server
You receive the following errors:
Windows update error 0x80072F8F
the item that this shortcut refers to has been deleted
hope this helps
Aug 21, 2012 | Compaq Computers & Internet
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Jun 29, 2010 | Nova Development Print Artist Version 22...
My ge electric range keeps on beeping f2
The F2 error code means: For an unknown reason, the oven temperature has exceeded a preset threshold.
This is GE's recommendation:
Before Calling Service, you can try the following...
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
GE does recommend turning the range or oven off at the breaker until you have it serviced. It is okay to cycle the breaker and turn the range or oven back on long enough to use the surface units. Be sure to turn the range or oven off at the breaker again when you have finished.
May 17, 2010 | Kitchen Ranges
SHORTCUT TAB
Hi sadiebay. It was not my solution for your initial post, but I think I can explain why you can not find the shortcut tab.
Because Internet Explorer is a Microsoft program integrated into XP, it is considered a 'Desktop Icon' item. The shortcut you are trying to find the properties tag for was probably put on the desktop using the Show Desktop Items routine in the Display Properties routine. It will not have the same right-click options available as a regular shortcut icon placed on your desktop.
The solution is to go to your Start Button->All Programs and right click on the Internet Explorer icon in the program list, then Send To Desktop. You will get another icon that looks the same, but you should notice that the new one has the small shortcut arrow on the 'E' where the old one doesn't. Now when you right click on the new icon (the one with the arrow) you get Properties as the last option, and within the Properties tab you should see Run with a drop down box next to it, in which you can select Maximized. Delete the old icon (right-click and delete, doesn't hurt anything) and put the new one in its place to keep your desktop set as you are used to it.
Dec 30, 2008 | Microsoft Windows XP Home Edition
Calendar question RX3715 / Windows 2003SE
yes the default is that the ipaq only keeps the past two weeks. To change this, open Activesync on PC, double click on Calendar.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
Computers & Internet Logo
56 people viewed this question
Top Platinum Computers & Internet Experts
john h
Robert Hunt
Tom Chichester
Are you a Platinum Computer and Internet Expert? Answer questions, earn points and help others
