Question about RCA 32V420T 32" TV
No picture or anything
If the power button is turned on, I do not get anything. The light blinks for a period of time then stays on. The tv is 1 year old. There is no menu, no blue screen, or no other feature to use. I cannot power the tv off without pulling the plug. Can you tell me what I could do? Thanks
  • 1,694 Answers
Re: no picture or anything
If your model # is 32V420T, your TV probably has a bad
transformer = part # 271996............if not,please provide......T.
Posted on Dec 04, 2007
0 characters
3 Points
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't stay on push on button and shuts off w/in 2 seconds
common to having a flyback transformer problem. this will require parts replacement
Dec 27, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Flashing green light
Did you try this yet
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
I have 4 32" Sony triton TV's that turn on and off
I think problem in power supply section and it would be nice if you could provide exact model number of your Sony TVs, question headings show it is KV-32FS120 TV, please confirm to proceed further.
Sep 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KV-32fs16 picture blinks + no input from remote + stuck in video 1 + no sound
the EEPROM chip has to be replaced and the coversion IC need to be replaced
as for the sound this may be a transistor pre amp or the volume IC
Oct 20, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony TV Toubleshooting Help
I had the same problem. Can't remember where, but I had to re-solder some joints. If you look very closely to the bottom of the motherboard, you might be able to see a cracked solder joint, otherwise carefully touch each one to fix it. Easy fix and the tv's been running flawless for going on 3 years now.
Be careful to not touch anything on the high voltage side with your hands. Even with it unplugged.
Apr 26, 2008 | Sony KV-32V65 TV
No picture or sound
Classic power supply or horizontal output problem. Take it to a servicer.
Oct 18, 2007 | RCA F32450 32" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
RCA 32V420T 32" TV Logo
78 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
