1998 GMC Jimmy Logo
Posted on Jun 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toyota avalon inside rear view mirror came off of mount
I believe the long black plasic thing covers the wire from the top of the mirror bracket to the headliner.
I can't figure out how to get slide the mirror bracket back on to the windshield mount. any ideas?
Anonymous
Level 2:
  • Expert 115 Answers
  • Posted on Jun 25, 2009
Anonymous
Expert
Level 2:
Answers
115
Questions
0
Helped
65063
Points
366
Sliding the rear view mirror onto the metal tab on the window. look at the part of the mirror that slides over the peice on the window. one end is open and has grooves on the side. you have to put the base of the mirror above the metal mount and flat against the window then slide it down over the mount. there may be a screw to hold it in place.
2answers
I want to swap my 2003 Toyota avalon drivers seat with my passenger seat. How do I do this myself?
The seats are not the same. the controls will be on the wrong sides. If you insist on doing this yourself then unplug the wire harness connectors on each seat and remove the 4 bolts holding the seat rail to the floor. There will be plastic covers on the bolts that just pop off.
Rear view mirror mounting hole cover (17K709)
The mirror is attached inside the door, you must remove the door panel, the part you think is just a cover doesn't come off.
HOW DO I CHANGE INSIDE REAR VIEW MIRROR PLEASE
If it is mounted on the windshield, the mirror is attached to a bracket that is glued top the glass. You will see a small set screw at the base of the bracket. Most likely an Allen screw. Loosen the screw and slide the mirror up off the bracket.
How do i install 6x9 speakers in a 1995 oldsmobile cutlass ciera?
No brackets are necessary...I believe you are talking about replacing the rear speakers located in the rear wondow shelf...Of course the speakers mount underneath the window inside the trunk...You can remove the rear seat and pull the interior trim back to view the top side of the speaker mounting...The opening is already cut for the 6X9 speaker...You can mount the top underneath the window cloth material like the factory did, or no need to remove the interior cloth if you use new top speaker covers, usually come with the speakers. Hope this helps.
1helpful
How to replace Inside Rear View Mirror on 2000
Hello, to replace the rear mirror, try the following:
1. Roll the passenger side door window all the way down. Turn off the ignition and remove the keys.
2. Gently pry the window control panel from the arm rest with the pry tool or screwdriver starting at the bottom of the panel. Flip it over and unplug all the wire harness outlets from it. Set the panel aside.
3. Locate and remove the two panel door plugs near the arm rest concealing the two screws and remove the screws with the Phillips head screwdriver.
4. Remove the door panel retainer plugs along the edge of the door by pressing in the middle of the plug to unlock it and removing the plug.
5. Detach the mounting triangle from the upper inside door panel covering the side-view mirror.
6. Remove the door panel by lifting outward and then upward. Disconnect the speaker wire harness from the underside of the door panel and set the door panel aside.
7. Locate and disconnect the mirror wire harness.
8. Pull back the foam insulation from the inside panel covering the side-view mirror.
9. Unscrew the three mounting nuts from the mirror using the ratchet, extension and a socket. Do not drop the nuts into the door cavity.
10. Pry the mirror gently away from the outside of the door.
11. Install the new mirror and replace the mounting nuts on the mirror studs and tighten with the ratchet, socket, and extension. Plug the mirror wire harness back in. Replace the foam insulation. Replace the mounting triangle.
12. Replace the door panel by reversing the procedure. Start by plugging in the speaker wire first.
Thanks
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
1helpful
How to replace mirror in toyota corolla
1) Disconnect the Corolla's negative cable to the battery.
2) Remove the triangle-shaped interior mirror cover from the top of the
door panel. Pry the cover off with your hands, a blunt plastic or
wooden tool to prevent damage to your door trim.
3) Take out the mirror wiring connection.
4) Remove the door trim bracket around the mirror. Take out the
mounting nuts.
5) Pull the power mirror off the Toyota Corolla.
1) Put the new mirror in place on the Camry.
2) Re-install the mounting nuts making sure they are securley holding
the mirror in place. Replace the mirror insulation.
3) Reconnect the wiring to the new mirror.
4) Install the triangle interior cover by snapping it back in place.
5) Connect the negative battery cable.
Thanks
Xeeshan
9helpful
3answers
Toyota Avalon Rear View Mirror
Hi-,
I had the same problem - the inside rear view mirror fell off during a hot summer day. I bought the mirror glue (adhesive) and wondered how to I separate the metal button from the mirror. Enventally, I tried the following and successully separated the metal button from the mirror: There is a little squre slot on the plastic sheath of the metal button. Please find a small flat-ned screw driver whose tip can fit into the sqare hole. put the screw driver into the hole and put it all the way inside down - which will open a little bended metal piece that stops the buttom; at the mean time, slide the metal button towards outside. As the bended metal piece opened uder the pressure of the screw driver, the metal button is freely moveable and can be slide out.
I did this successfully for my Toyota Avalon 1998 car.
Hope it helps.
Wei
Avalon door panel
Below are the removal procedures for your vehicle's front inner door panel.
On models without power windows, remove the snap ring retaining window crank handle. Remove crank handle and cover plate.
Remove lower door frame bracket garnish. Using a screwdriver, remove inside door handle bezel. Remove power mirror control switch and disconnect harness connector.
Remove armrest panel. Remove 6 screws. Pry interior door panel loose from door.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
