Question about Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED
XPS won't allow me to insert a CD or DVD. It appears lockedc?
I can't insert a cd or dvd. There is a little noticable hinge and I can't tell whether or not I already have a CD in side or not?
  • 258 Answers
Manually open the drive by inserting a pin into the small pin hole on the front of the drive
Posted on Jun 25, 2009
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
Dvd rom will not work
This is normally caused by missing or corrupt drivers for your CD drive. Again if the CD drive is not properly connected to the motherboard of your laptop, this can also happen
1. Try to restart the laptop and observe the results. Make sure there is no CD in the CD drive.
2. If you still have the same result, go to "my computer" and check whether the CD ROM
appears on the list of devices. If it appears then, right click on it and try to eject.
By doing this you want to check whether the CD tray is still mobile and not blocked
by anything else.
3.Then right-click on it again and go to its properties and go to the "Hardware" tab
4. In the Hardware tab, notice the list of drives connected to your laptop and choose the Cd Rom and go to "Properties"
5. Notice at this point, whether the device is said to be working properly or there is something wrong with it.
6. Then go to the "Driver" Tab, and choose "update driver"
6. This will let your system look for the missing or corrupt drivers for your CD drive.
Restart your computer and observe the results
Aug 18, 2011 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Cd stuck on cd drive in Dell
If the Cd drive is not ejecting, try going into My Computer, and right clicking the Drive and selecting "Eject". If that doesn't work, then take a paper clip (or any other piece of wire that small, which does not have a sharp end) and examine your CD/DVD drive. There should be a little paperclip sized hole, this is usually next to the Eject button. Slowly push the paperclip into the hole, until you feel that you have pressed something, and then remove it. The drive should eject. This should work regardless of whether the computer is on or off.
Jul 05, 2011 | Dell XPS One PC Desktop
I have a Dell XPS M1530, When I insert a CD it comes back out
go to control panel.......sytem.......hardware tab........device manger....dvd/cd devices.....find the one you are trying to use.....double-click it and go to the driver tab......go to update driver and follow the istructions from there. If it says there are no better drivers for your device then go to Dell and look for drivers for that hardware and download to your desktop and then install
Jul 31, 2009 | Computers & Internet
CD/DVD Drive missing. No UPPER or LOWER FILTERS
Shut down the laptop completely and then Remove the CD/DVD Drive from your laptop and restart it. Then See whether it notices it absence or not. Shut It down completely and then put the CD/DVD Drive back in and then Restar it and check again whether its appearing or not. if not then-----------> Go to BIOS and make sure that bios is detecting the CD/DVD Drive and its ON. It would Surely solve the problem. Install any New Firmware From For The CD/DVD Drive available on the HP website.
May 01, 2009 | Microsoft Windows XP Home Edition
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Cd/dvd device
Goto BIOS settings check whether DVD writer is enabled.
Oct 25, 2008 | Acer Aspire 5315 Notebook
Insert disc code 011-02-1028
It may be compatibility issues with that certain blank dvd media, dvd drive may not have dvd writing capabilities or drive is faulty.
Feb 20, 2008 | Toshiba (SD-R2412) for Satellite A10, A15,...
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
See all Dell XPS One All-in-One TV Desktop with Intel Core Questions
Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED Logo
183 people viewed this question
Alun Cox
