Question about Whirlpool GS5SHAXN Side by Side Refrigerator
If the light is not working on the switch and the ice dump is working sill the soliniod on the water inlet valve stop working
SOURCE:
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
  • 833 Answers
SOURCE: Ice maker
There is a slide switch near that flashing light. Move it to on.
Posted on Jan 03, 2008
  • 145 Answers
SOURCE: Ice maker won't make ice
It sounds like the fill tube coming through the freezer wall is frozen shut. Need to carefully take a hair dryer to it then recheck with wire swap. If you turn i/m off for a couple hours then back on you should be able to watch the fingers go around. If so you module should be good.
Posted on Apr 23, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore ice maker filled with ice, but not dumping. light blinking next to ice maker switch
unfortunately, the heater is molded into the unit.
without testing every part of the icemaker there is now way to be certain which of the following has failed...
USING THIS DIAGRAM -
#11 is the heater assembly
#17 is the thermostat that controls the heater.
An entire unit replacement is not necessary.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 27, 2009
hiltonjug
  • 612 Answers
SOURCE: Ice maker not dumping out ice
Your ice maker has a heater on the bottom of the tray that heats up the tray enough to allow the ice to release from the tray. It's energized when the ice maker advances to a point that the fingers touch the ice. There is a micro switch inside the head that turns the heater on. You will need to remove the ice maker to repair it. You should have two 1/4" bolt on the top and one or two on the bottom ( Don't know which model you have). If I knew the model number you have I could tell you what you would be looking at after you pull the front off the head of the ice maker. There are two major types. One you can test while still mounted and the other you can advance only. Once you have taken the unit out, you can ohm the heater. If it's good, your problem will be the micro switch. It cost around $8.00. If the heater is bad, you can replace it, but It's hard to do and I think you will find it will be better to replace the ice maker. I have replace a few and around half didn't work afterwords due to them breaking while installing them. You have to bend the metal over the element ot install and it's tricky to do this without breaking the element. I Hope this helps. Please rate my solution. Thanks
Posted on Sep 05, 2009
Testimonial: "Thanks for heading me in what appears to be the right direction. Will"
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not making ice
Nov 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice machine stopped making ice
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jun 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
The water was turned off the the ice maker and then turned on a few days later.....now the ice maker will not make ice......it will not fill up with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} put water in it and see if it dumps the ice after it’s frozen. I
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 14, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker stopped working cant tell if its getting water or not
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Nov 21, 2009 | Amana Refrigerators
Ice maker stopped working...
Aug 31, 2009 | Refrigerators
The ice maker has stopped working
Aug 24, 2009 | Freezers
Ice maker stopped making ice
Aug 19, 2009 | Refrigerators
Ice maker does not make ice
Aug 15, 2009 | Refrigerators
I have Maytag MTF1954ARA with ice maker which stopped working. Water is available, filter OK, Water inlet valve removed and tested OK. Is there something else to check before I have to remove/replace ice...
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Aug 02, 2009 | Maytag Refrigerators
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
20 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
