SOURCE: air leak
Several models of hitachi nailers share the same orings and other parts including the check ball under the trigger pin in your gun. Remove the roll pin holding the trigger to release the trigger pin, (plastic with one oring) then remove the valve with a screwdriver. Replace the vinyl check ball and seal. Parts are available at www.toolpartsdirect.com. This should fix the problem that you are describing, however use caution and check that the safety if properly adjusted. Enjoy
SOURCE: doesn't shoot. makes the noise, but no nail comes
I have had this problem myself, the only fix is a rebuild kit which you can pick up pretty cheap on ebay. the kit will consist of a bunch of seals and just pay attention to the way you take it apart and you will have no problems
