Schaerer Siena Espresso Machine Logo
I have a schaerer ambrente plus, the one shot and three shot button works, but the two shot does not. When press, it continues to grind the beans.
I can pull a single or a triple shot, but the double shot does not work. When press it continues to grind the beans.
Schaerer Coffee Art Plus continuously leaking?
Question edited to throw in a few capital letters for 'proper names'.
There is either a leak in the water inlet valve, plus worn o-rings in the brew head. These machines require a lot of ongoing maintenance. It isn't a machine I know, I have have used many commercially, but there is help here.
https://www.google.com/search?q=Schaerer+Coffee+Art+Plus+leaking
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
My breville bes870xl filter light won't stop flashing single and double. I've unplugged the unit and plugged it back in and turned it on and it still continues to do this.
PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page
rested coffee beans produce espresso with much more taste .... filter size you select, and along with the GRIND. AMOUNT dial ...... create steam. When the steam lightstops flashing it is ready .... cappuccino machines is purchased. THE RIGHT ...
Set grinding and extraction on ambiente
Grinder setting will not just affect extraction time, it will also affect taste. A fine grind will be slower but have a creamier look, a coarse grind will speed up delivery. From whatever setting you are on look at the result, you are after the good creamy top of a good expresso. only adjust one step at a time, and check a few cups before any more adjustment. You do not want it so slow that you have to wait ages, So go for coarsest grind with a creamy head. Overtime you might have to readjust due to wear, Select only one hopper at a time to adjust, Do not try and adjust when blending, one side at a time until both give same result and speed for same coffee, Then you can go onto blending.
2helpful
3answers
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
3helpful
2answers
Add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Good Luck!
2answers
Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
2answers
Opal telling me beans lid is not on when it is ?
hi
i work on schaerer machines. on the back of the lid there are two plastic spikes that make contact with in the machine, when you lift the lid it breaks contact so when you select your product you dont put your hand near the grinder. order a new lid or write back and ill tell you how to jam it open. If you want?
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Top Schaerer Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Liza Cat V
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
