Question about Sennheiser RS130 Wireless Headset
No sound from RS130 headphones
I bought Sennheiser RS130. I plugged the base into the TV through audio and into the electricity, the base appears to be working fine with the lights.But the headphones do not respond to him. When I put them on to charge it stayed with the red charging light for over 30 hours now, it says it needs 16 to be fully charged. When I turn them on I get no beeps, when I press the tune button nothing happens. I tried using other batteries but it's the same.
Please someone help. Absolutely nothing works.
  • 26 Answers
The headphones are not sync'd with the base unit, leave headphones in base and just pull the power from the base, count to 10, repower and wait for setup to complete.
if still no audio in headphones try setting control switch in different position until audio is heard
Posted on Jul 19, 2014
    New Friend:
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Posted on Nov 24, 2009
SOURCE:
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
What batteries do i need for the sennheiser rs130 headphones please
You need 2 AAA batteries to put in sennheiser rs130
Thank You
Dec 02, 2010 | Sennheiser RS 130 Consumer Headphones
Headsets receive no sound
if you have the headphones plugged directly into the audio out, then thats the problem. the audio only supplies a low volume, pre-amplifier output and this needs to be put through an amp of somekind to get a decent volume. Look for a headphone socket on the tv, usually near the s-video plug and coloured green.
May 09, 2010 | Sennheiser RS130 Headset
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
How do you get a sennheiser RS 130 headset to work in a computer?
i told u so kayla. a sound card upgrade is necessary so the connection would work.
plz rate!
Mar 06, 2009 | Sennheiser RS130 Headset
Unable to connect headphones to Tv.
You TV have no headphone port.
You can download the user guide for your reference from:
https://docs.sony.com/release/KDF55WF655.pdf
Apr 24, 2017 | Sennheiser RS130 Headset
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS130 does not appear to turn on
did you try to put regular batteries in to see if that works?
May 20, 2008 | Sennheiser RS130 Headset
Sennheiser RS130 Wireless Headset Logo
541 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Ekse
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
