Question about Honeywell Programmable Thermostat Heater
How do you change a battery in a honey well thermostat
  • 334 Answers
Hey there, the front of the thermostat is clipped onto the part attatched to the wall. It should pull off and then you will see the battery right there. Some models have a compartment in the top left corner that pulls out sideways to reveal the battery, let me know if this helps or you need something else.
seth
Posted on Jun 25, 2009
Honeywell thermostat 8000 series- some of the buttons on the screen are not working. Replaced the batteries-still no fix. Read that there is a 3 volt battery also. Do you know where this is located?
Base on my experience. It's not fixable. Better just buy a new one. Don't has to be Honey Well brand. You can buy
any brand from Lowes or Home depot. It's compatible.
Good luck and enjoy
Mai Lor
Oct 18, 2017 | Honeywell Heating & Cooling
Honey thermostat RTH6500WF IS BLANK SCREEN
Change the battery in your thermostat first. The next likely issue would be condensation not draining. I would bet your air handler is in your hot humid attic. That means you have a drip pan under it and likely a tube from the air handler leading to the out side to allow condensation to escape to the outside of your home. On that tube from the air handler, there is a float switch which tells the A/C system to shut off so condensation does not back up into your house and ruin your insulation or ceilings. That is likely why your thermostat goes blank. The tube that drains condensation from the air handler to the outside builds up a slimey substance over time (especially in high humidity) and that clogs your drain tube. Using a shop vac, either blow the tube out or suck it out. Manually reset the float (should be down). You can find the float in the tube simply because it "should be" the only thing on the tube that has wires coming from it. Reset your thermostat using the switch for your A/C in your fuse box.
Oct 16, 2014 | Honeywell VisionPro 8000 TH8110U1003...
1987 honey rv
sorry would need a look to know what they do ,try asking a local mechanic who can tell you with a quick 2 second look
Nov 21, 2013 | Cars & Trucks
Honey wire
Look for reset button push in and try to Program if this doesn't work time to replace T-Stat.
Jul 05, 2013 | Honeywell Programmable Thermostat Heater
My central heating is not working. ihave honey well mercury 20v thermostat
You can easily check the thermostat by jumping across the R & W terminals. If the furnace fires your problem is the thermostat. If not, the issue is with the furnace or the wire between the thermostat and furnace. I can walk you thruogh a dignostic check but you will at least need a volt meter.
Mar 05, 2013 | Heating & Cooling
Trying to put new honey well thermostats on but, old cozy thermostat only has two wires. Wires are not labeled, what are the wires?
on a 2 wire t stat the wire color does not matter much .but on the thermostat you want to use rh and w connection point.other terminals are for fan and cooling
Jan 29, 2011 | Cozy (W352E) Heater
Screen freeze
Try pushing hard and steady on the bottom, left side of the thermostat, if it unfreezes, it means that the ribbon connection from the base to the touch screen is loose. you can try to wiggle it, but usually it will not stay fixed and the thermostat must be changed.
I'm very sorry.
Sincerely,
Paul Gibson
May 05, 2010 | Honeywell Programmable Thermostat Heater
I have amanual honey well and I want to change it to a programable honeywell but the two wires on the manual thermostat are not labeled, so I don't know where to connect the wires to in the new thermostat
Wires for thermostat control circuits are normally color coded. Check for proper connections at the furnace and connect the same colored wires that you find at the furnace to the like lettered terminals on the new thermostat. R to R, W to W , Y to Y , ans G to G. R is for power to the thermostat, W is for heating, Y is for cooling and G is for furnace fan operation.
Nov 14, 2008 | Honeywell Heating & Cooling
Digtal thermostates
Give this number a call if you are in the US, 800-341-0110. You will need the COMPLETE model number not just 230B. Something like YRTH230B1009. They can link you a manual via email.
Nov 13, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,035 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
