Samsung AC keeps popping breaker
I have a Samsung model # aw12ec87 air conditioner that is 2 years old and reside in central Colorado. In the last week, my AC keeps popping the breaker when I put it at 68 degrees, so I tried 70, 72, 74 degrees and it still pops the breaker.
I have done everything I can think of. I clean the filter everyday cause I have cats and dogs. I have also removed the front panal and cleaned inside there very careful and throughly. Also, tried a brand new extension cord, as well as other outlets in the house on different circuit breaker. None of that has help solve the issue.
The last two summers I have had no problems putting the AC temperature as low as 64 degrees. You have any other suggestions I can try? Thanks!
  • cesmith_98 Jun 25, 2009
    I do not have a power outlet near the window the AC is in. I tried a heavy duty extension cord yesterday and the circuit still popped. So puzzling since I never had problems with it the last 2 summers.
  • 92 Answers
Use larger extention cord with thicker wiring,as short as possiable!
Posted on Jun 25, 2009
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
Our bedroom Samsung AC died last night-really need it
Samsung AC died, really need it.
If the air conditioner blew a fuse or a breaker was tripped in the house, then reset the breaker or replace the fuse.
If the air conditioner fan works, and it's blowing hot air, then the freon level may be low in the air conditioner's piping system.
If the air conditioner is less than 30 days old or within the warranty period, take it back where you bought it for a replacement.
If it needs recharged, contact an a/c repair place that can recharge it.
Actually, new air conditioners cost around $100 which is very reasonable considering how it affects comfort and safety in the room it is used.
These are a few ideas that I would think about if I were in the same shoes as yours.
Good luck fixing it.
Jul 08, 2010 | Samsung Heating & Cooling
Internal breaker in the plug keeps clicking off, when i reset it clicks off again. ive replace the Main House breaker, thinking it may be old, but still the inline breaker keeps popping off. this Ac/Heat...
Inspect the wiring and the terminals. There may be a short circuit somewhere. If you have a tester, you may check the continuity of the two wires. Test the wires after the breaker, the part that goes to the unit.
May 05, 2010 | Fedders AER24E7A Air Conditioner
My breaker pops when i switch the unit to coo
Sounds like compressor has shorted
Aug 07, 2009 | Heating & Cooling
Amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Jul 11, 2009 | Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM...
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
AC tripping breaker.
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
May 25, 2009 | Goldstar GW-HD5000 Window Air Conditioner
No central air
Check for power to the outdoor unit. Just because the contactor closes does not mean line power is available. Look for a tripped or turned off circuit breaker, possibly fuses if your residence is much older.
May 19, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
