Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Freezer and fridge to cold setting does not seem to work
The freezer is to cold and so is the fridge. Termostate on warmest position
    Problem Solver:
  • 19 Answers
The thermostat faulty or sensing piece not against the evaporator.check that the thermostat supplied is for the right fridge.eg:that is not a freezer stat that is installed in the fridge compartment.
Posted on Nov 05, 2007
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Hi, I have a fisher and paykel fridge for almost 3 years.The problem is that the ice cube maker stop working. I have check all the things that are mention in the fridge guide, water supply is fine, the ice...
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Jan 29, 2011 | Fisher and Paykel Active Smart E522B...
Fridge working not cold no freezer section
first you should check the termostate how much temp you keep.then if your compressor is working properly so check the refrigerant in system.it may be more chances lake of the refrigerant.oil increase in L.P side.you also should check the thermostate is proper working or not.chaces of low pumping in the comp.either door gasket likage or freezer door ofently open.
Feb 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
266 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
