Question about HP DeskJet 812c InkJet Printer
Hp deskjet 812c changed both ink cartridges but it will not print
I replaced both ink cartridges but the orange light is still blinking and it will not print. I can hear some noise in the printer now but it is not doing anything. how do i solve this
  • 4 Answers
It's Not possible to solve urself, contact service center
Posted on Jun 25, 2009
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
Hi,my hp 3100 all in 0ne will not print. ican scan but not print
You failed to tell us whether the orange indicator light is blinking. 'usually this scenario causes the orange indicator light to blink continuously. If that is the case, i.e. the orange light is blinking, then it is an ink issue; either the cartridges are bad or their electronic panels are dirty.
Below are the solutions to the two situations
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Oct 20, 2010 | HP LaserJet 3100 All-In-One Printer
Need to install new ink
Lift the entire top including the scanner portion until it clicks to stay open by itself (like some vehicle hoods). You should see the print head containing all the ink. It will slide back and forth for a moment, this is normal. Wait until it comes to a stop. Notice any blinking lights below the ink cartridges. If the light is solid, there is enough ink. If the light is blinking you'll need to replace that cartridge for the best print quality. Remove the ink by carefully but forcefully pushing on the tab with one finger and holding the back of the cartridge with other. It should simply slide out. Note the EXACT #'s on the ink cartridges. Right down all the information and the type of printer you have and take it to your local best buy or equivalent store, they will give you the replacement cartridges you need. Unwrap the package and carefully remove the orange tab on the bottom by twisting in the direction shown. (You may want to wear rubber gloves because the ink stains fingers badly.) Carefully but forcefully slide the new cartridge in place of the old and push down until you hear a click. The light under the cartridge should now be solid. Once all carts have been replaced close the lid of the printer and give it a moment to situate. Run a print head alignment to manually align all nozzles for best printing quality. Simply click the head align software button and follow the instructions, quite easy. You should be all set and ready to print!
Jun 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Changing ink cartridges
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
Oct 15, 2008 | HP DeskJet 990cxi InkJet Printer
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
HP DeskJet 812c InkJet Printer Logo
479 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
