It does not turn on. timer indicator is blingking
Air cond samsung timer blingkin what problem
Look closely on the remote. Find a small slot as if you can only use a ball point to insert to it. If it has this small slot, this is the reset button. The clock would reset, the timer would be off and you can change the mode to cool for the unit to run on a/c mode.
In some remote, this could be inside the battery compartment. In some style where there are flaps that you open in order to activate some more buttons, then it would be inside .
If there is no reset button, you will just have to press the timer button repeatedly until the timer LED on the indoor unit would dis appear.
If you need any other assistance check us out at AC Delrey Beach
Mar 04, 2015 | Samsung Heating & Cooling
2011 zmr's fuel pump continue not working..and fi indicator is blingking continuesly.so what i can do this....
Check fuses, relays, and lastly pump. Probably need to replace pump if any of the other items test bad.
Jan 29, 2015 | Cars & Trucks
IN5532, problem: Indicator power on (green) Indicator service: on (red) Indicator lamp: blingking (red) Please, what kind of this problem indicated? And how to fixed? Thanks
Power - green - is good.
Service - red - is not so good
Lamp - blinking red - is not so good
For dual-lamp projectors, one blink off every 2
seconds means the problem is with lamp #1; two blinks off
every 2 seconds means the problem is with lamp #2.
So how many lamp blinks do you have?
Mar 19, 2011 | InFocus IN5532 Projector
It is blingking when you turn on..and nonthings hapen its jus blingking
-the operating system that you have is corrupted, you need to reinstall the OS, if it is XP you need to use repair install so that you can get files an picture in the computer
windows xp installation guide http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
-if it is vista or win 7 just install that OS to the main partition and you can get files in the windows.old folder in drive C:
install windows 7 guide http://www.techtalkz.com/windows-7/514412-windows-7-installation-guide-tutorial.html
cheers
Feb 23, 2011 | Computers & Internet
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
When I turn the tv on, no picture and only the stand by timer
Sound to me like your video amp failed on the C board. This board connects directly to the back of the CRT tube. It actually has the letter C on it. The video amp is IC702, PN: TDA6108JF. You can locate a vendor for the part by googling the provided PN. This amp is fairly cheap and not too difficult to replace if you can use a soldering iron. However, you must apply heatsink compound or it will over heat and fail more quickly. You should be able to get a tube from the same vendor as the amp. I hope this was helpful, best wishes.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My fuji xerox printer docuprint 203 A's drum lights/blinks when i turned on my printer to print. help.
Press the button until all the lights are on..then let go the button, this will reset your drum counter.
Feb 18, 2010 | Xerox DocuPrint 203A Laser Printer
It does not turn on
it does not turn on- timer indicator is blingking help pls!
Jun 25, 2009 | Pioneer AVH-P7480DVD Car DVD Player
27 people viewed this question
 Grubhead
Grubhead
