Question about Karcher K 5.85 M Electric Pressure Washer
Why wont my detergent applicator work on my new karcher k5
2 Suggested Answers
aroostookb
  • 98 Answers
SOURCE: Karcher detergent draw problem
return it to Walmart
Posted on Jun 23, 2009
Hi. I have a karcher pressure washer k5.85 it wont switch on. I have brought a new macro switch and new capacitor. still wont turn on. thank you.jack.
Jack,
This YOUTUBE may help point the way?
How to Diagnose Pressure Washer Electrical Problems
Also it appears that your K5 has a GFI?
WITH THE POWER DISCONNECTED:
Can you jumper ACROSS the GFI and CAREFULLY see if your K5 powers up?
While I found plenty of parts lists, I found no schematics! Darn.
Anthony
Apr 15, 2018 | Karcher Garden
Why is my detergent not working on my new k5 pressure washer
If you are referring to an electric washer,The wand for the detergent is a double action wand. You usually pull the wand end out for low pressure and detergent flow.
May 30, 2014 | Garden
Why wont my detergent flow?
Detergent only flows then the lance is set to lowest pressure.
May 30, 2014 | Karcher K 5.85 M Electric Pressure Washer
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
I have karcher k4.98. I can not get the detergent to come out. I have checked the trouble shoot in the manual and all items are ok. Any ideas ?
Just had the same problem, brand new machine, the detergent feed pipe was squashed under the bottle holder bracket!
Dec 30, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
KARCHER K210
If your discussing the crankcase, you can use regular non detergent SAE 30 wt. Do not use the new types of oil as they have additives that may cause harm to the engine.
Mar 16, 2008 | Karcher 2500 PSI Pressure Washer
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
78 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
