Question about Janome Sewing Machines
Run away foot pedal.
I have a Janome Platinum 720. I have had a recurring problem with the foot pedal sticking when depressed. When I take my foot off the pedal, it continues to sew. The only way to stop it is to turn the machine off.
I live near the ocean and suspect that the contacts become corroded. I have taken the foot apart and polished the contact which seems to fix the problem for a while. Now, however, it only works intermittently and gives frequent Fc error codes. I suspect that I need a new foot but I can't find a source for it. Please advise on how to repair or where I can purchase a replacement foot pedel.
I had this problem with my Janome and also after I was given a new foot pedal as well, even though no fault could be found with it. I then suspected power surges as my computer went haywire at the same time on one occasion. I have never yet had the problem since I started to use surge sockets. I have only ever had the problem with my computerised machine, not my other although the foot pedals are the same.
Posted on Oct 07, 2012
I also have this problem with the pedal to my Janome Platinum 720. Took it to my dealer yesterday and the pedal is NOT under warranty and it costs $80 to replace. That is outrageous and I am trying to find another solution. They (Who??) are ripping us off. My machine is only year and half old and I only use it to take to classes. My Kenmore and Necchi machine pedals are still working after many many years of use.
Posted on Jul 17, 2010
Sewing machine runs in reverse when turned on. Will run forward when reverse button is pressed. What's wrong?
Are you using buttons on a footswitch or on the machine? If a footswitch, check to be sure the switch's cord is not plugged in upside-down. You might have to open it up and swap wires to the switches.
Apr 03, 2015 | Janome Dreamworld Table for Sewing Machine...
Machine ran on when pedal when released, pedal now no longer works and machine wont sewing more than one layer of fabric without getting jammed
How are you making it run now since the pedal doesn't work?
You probably should take it to a repairman/shop. When this happens, sometimes the pedal is shorting out and it kills the pedal and you will need to buy a new pedal. When it ran by itself, it might have either gotten a piece of material or thread caught in the shuttle or it might have knocked the machine "out of time" and you will need to have it put back in time so that it will run properly again. I don't know what the prices are in your area but I would imagine that it will all run about $125. Sometimes you can get a used pedal off ebay (check to make sure that the configuration of the plug is the same). Good Luck.
Mar 12, 2015 | Janome DC3050 Computerized Sewing Machine...
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
Foot pedal slow +Janome 9700
There is an adjustment on the machine itself that controls how fast the machine is able to run. It is just about the center of the machine, right above the work surface of the machine. It has one arrow, two arrows and three arrows. When the slider is at the one arrow, it is at the slowest speed. You can move that back and forth depending on how fast you want your machine to run. I hope this helps.
Mar 10, 2014 | Janome Memorycraft 9700 Computerized...
My Janome sewing machine keeps sewing when foot pedal is disengaged
it would be a good idea to have the machine checked to see
if there is a short in the wiring or in the foot pedal socket
Mar 21, 2013 | Janome Sewing Machines
Foot pedal error
Yep same thing .....the thing is possessed started running by itself when I was at the iron. Dealer said never heard of such a thing and acted like it was me. Also will not stop sewing when take foot off pedal. Dealer charged me $95 to clean machine and said nothing wrong with foot pedal. Ugh. Has anyone replaced foot pedal and found the problem to stop properly?
Mar 15, 2012 | Janome Memorycraft 6500P Computerized...
My Janome sewing machine wont stop.
The only thing I can think of is that the foot pedal may be slightly stuck and not returning fully up after being depressed. Unplug the foot pedal and check for anything stuck there then give it a good wiggle up and down a few times.
Oct 19, 2011 | Janome Memory Craft 9000 Computerized...
The sewing machine works when switched on, the foot pedalhas no c
there is a clutch operated by foot pedal. if the clutch is continuously engaged then it will run own its own. so adjust clutch lever.
Nov 23, 2009 | Janome Sewing Machines
Sewing Machines Logo
806 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
