Question about Quasar VV-2002 20 in. TV/VCR Combo
No power, doesn't turn on
This TV won't turn on, no power - happened at same time of the changeover to digital. I still want to use it for VCR, wonder what the problem is.
I have 2panosonc vcrs with digital tuners can I time record programs after Spectrum cable service goe digital this month?
If the tuners are really able to receive a digital signal you will have no problems. A digital vcr is a fairly rare item, around here at least because before the signal went digital no one needed a digital vcr and the HDD recorders were available much cheaper than a digital vcr after the changeover.
A digital vcr was and still is around four times the price of the analogue type. After the switchover there were a few dual standard machines around and quite a few people who mistakenly believed they owned digital machines.
Feb 06, 2018 | Televison & Video
DGM tv not saving channels
If only the freeview channels I wonder if a issue with the digital changeover or such?
Nov 05, 2012 | Televison & Video
Hyundai Iload diesel won't start, have replaced engine in van with changeover from wrecker & it turns over but doesn't fire up
run the scanner to reset the ECM and immobiliser
make sure that the cranking speed is fast
check for air in the system
check that the stop solenoid is connected
Nov 03, 2012 | Hyundai Cars & Trucks
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Digital or analog?
As long as you are on cable you will not need a box.
Mar 28, 2008 | Toshiba CF19G22 19" TV
Quasar VV-2002 20 in. TV/VCR Combo Logo
107 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
