Question about Dryers
No heat replaced thermal fuse #3392519 and thermal cutoff #279769 ohms reading on back of dryer label says heater coil 7.80-11.80 mine is 28.30 whats next
  • jason hersh
    jason hersh Jun 25, 2009
    thanks for your help i will try that in a day or two and get back to u
  • 508 Answers
Replace element
Posted on Jun 25, 2009
The dryer blew the thermal over load on the heater coil I replaced the over load and therostat and it blew the over load again. What should the ohms be on a good heater coil kenmore dryer model...
Hello, The ohms rating on the heat element should be appx.10-20 ohms. The reason a thermal cutoff would blow and the replacement also blow was a poor air flow issue, so to much heat was being retained in the heater housing. What ya would need to check is for lint build up in the lint filter housing and also a blocked or restricted vent tube.
GENE
Oct 09, 2011 | Dryers
Kemnore 80 electric dryer: dryer spins, light works, heat does not work...used multitester on ohm setting to test for continuity on coil and thermal fuse...both seemed to be fine...back to square zero
In addation to testing the element and thermalfuse what ya need to check is both of the thermostats that are on left side of teh housing where the heat element fits into,both of those should have zero ohms resistiance,also should check the cycling t-stat there where the thermal fuse (in the blower housing) be sure to not confuse the thermal fuse which is the blower housing with the thermal cutoff which is on the heater housing that and the high limit t-stat are the ones in the heater housing and are the most likely things making the dryer not heat.
If all above checks to be good, the timer, or the motor is whats wrong causing it to not heat.
GENE
Sep 20, 2011 | Kenmore 63942 Dryer
Dryer does not heat up
Hi.
Start checking if the ignitor is working and if flame is coming on. If igniter is not working, replace the igniter. If there is no flame test the coils contacts using a multimeter set on Ohms. The coils must return continuity between two of their contacts or they are defective and the valve will not be open. Replace defective coils if needed.
Test and replace the thermal fuse.
The part is tested touching the fuse contacts with the probes of a multimeter set on Ohms. If the fuse is good it will read zero. A bad fuse shows Ohms infinity (open).
If fuse is not the culprit, then you will need to reach the thermostats, testing them with the multimeter. apart the thermal fuse there is one thermistor and one thermal cutoff.
When you access the thermostats clean the lint from air ducts. If fuse or thermostat has blown it means that lint or poor ventilation has caused overheating.
Check fuse if problem is not fixed test the thermostats.
Regards.
Ginko
Jun 14, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore series 90 electric dryer will not heat. Have replaced thermostat-thermal cutoff and thermal fuse. tried bypassing all by connecting wires with electric tape to test with no results - There are no...
Okay Element should read around 38 OHMS if okay providing the voltage is at the element then it should heat, if no volts then check stat , cut outs and timer, in that order
Feb 22, 2011 | Dryers
Whirlpool dryer model LER7646A blows cold air. The heating element is intact and shows resistance on the ohm meter.
make sure you have 240 volts going to the dryer,your filter is on top so remove the back panel,if the dryer hasn't been cleaned out in over two years check the thermal fuse,if that's good then check all the thermostats on the heater box,unplug the dryer,you have to remove at least one of the wires on the part you're checking with the meter,read out the parts,like i said start with the thermal fuse located to the right of the duct that the lint filter slides into,it's white and it's a 3392519.if that's good move down to the heater box.let me know what you find
Jan 19, 2011 | Whirlpool Kitchen Ranges
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
